Cinema4D version 2021.1.7 (Old stable) 16.12.2022
stefano-dear
aoktar wrote:
stefano-dear wrote: I also tried version 2021.1.6 but it still crashes. I only have one texture displacement
It's looks like your geometries or vertex displacement. Having one displacement doesn't mean that will not crash. It's possible if you go high on tessellation.
It seems strange to me because the surface with dispacement is very small and the resolution is only set to 1024.
In attached two other crash reports if could helps
bugreport_20220928_130342.zip
(1.91 KiB) Downloaded 144 times
bugreport_20220928_123243.zip
(3.4 KiB) Downloaded 137 times
stefano-dear wrote: It seems strange to me because the surface with dispacement is very small and the resolution is only set to 1024.
These are not bugreports with crashes. Better to contact to support with your scene and details about errors.
Torquee
Hi Ahmet/Team,
Having endless crashes with a project when starting Live Viewer and after I add another material to an object with a polygon selection it will crash every time.
Cinema 4D R26.107
Octane plugin 2021.1.6-R4-win
RTX 3090 24Gb
Titan Xp 12Gb
Attaching crash reports. Any direct clues on what is going on?
Please be gentle, I am new to PC ;)
Grateful for a solution as work is now halted.
220928_2 octane 2021.1.6 220921 130320.txt
(201.63 KiB) Downloaded 134 times
220928_1 octane 2021.1.6 220921 130320.txt
(101 KiB) Downloaded 131 times
jayroth2020
@Torquee, please file a support ticket at [email protected] and include your scene and associated textures. Do this via File > Save Project As... — archive the result and send it in.
Torquee
jayroth2020 wrote:@Torquee, please file a support ticket at [email protected] and include your scene and associated textures. Do this via File > Save Project As... — archive the result and send it in.
Many thanks!
Delizade
hi,
I can't solo sub nodes of a mix material.
mixMaterialSoloNodeProblem.zip
(175.21 KiB) Downloaded 132 times
Delizade wrote:hi,
Try to convert the Mix Material into a Composite Material, by going in Live View menu Materials/Convert material command.
Mix Material has several limitations, always better to use a Composite Material instead.
ciao,
Beppe
Delizade
bepeg4d wrote:
Delizade wrote:hi,
ciao,
Beppe
Solo node feature does not work on Mix material as well.
I can't make tests right now but currently I can't view solo nodes.
I will try to make some tests another time for this issue, I don't know it is happening for me or it is caused by plugin I'm not sure.
jayroth2020
Mix Material is essentially deprecated. I would not expect to see any changes in that regard.
Kalua
jayroth2020 wrote:Mix Material is essentially deprecated. I would not expect to see any changes in that regard.
Any plans to get rid of MIX materials?
Hope not since I find good to have different options for different workflows scenarios.
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Return to “Releases”
