I have I7 6850K. Also noticed that continuous material update turned off in C4D viewport display preferences helps a little.aoktar wrote: What's your CPU? New style is using a CPU based graphic library, so it may be related to your CPU performance. This is the performance of it on me. It's faster than old style for complex cases with highest drawing quality.
Cinema4D version 2022.1-XB3-(R4) (Experimental) 23.09.22
- LOVEXMEDIA
Super happy to be in Octane 2022 on Cinema4D 2023! Thank you as always!
Edit: I did come across a few crashes randomly. I wasn't doing anything spectacular for any of the crashes. I was in the node editor and was navigating around and it crashed. I tried to replicating it and didn't crash so I'm not sure what is happening.
I added the last few bug reports for your review! It might be something I was doing or how I'm setup but I know you all will know what's up! Thanks in advance!
- bugreport_20220913_140432.zip
- (1.49 KiB) Downloaded 109 times
- bugreport_20220913_131337.zip
- (1.5 KiB) Downloaded 115 times
- bugreport_20220913_120647.zip
- (1.36 KiB) Downloaded 108 times
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
Thank you for adding remove all option for stored render comparisions !
2023 and Octane is fragile for now! I'll try to fix the issue. That's coming from used library for new node graphics.LOVEXMEDIA wrote:Super happy to be in Octane 2022 on Cinema4D 2023! Thank you as always!
Please see, there is still issue with Octane Object Tag shadow visibility on objects with materials that have opacity channel. Shadows are still visible until Alpha Channel in render settings is not turned on.
This issue is on all objects. Shadow visibility doesn't work if Alpha Channel is disabled - manual says different.
It crashes very often even using old node styleaoktar wrote: 2023 and Octane is fragile for now! I'll try to fix the issue. That's coming from used library for new node graphics.
It's not matter what you do, I don't mean to use the new style. It's causing complete unstability. Just don't use the plugin if you need stability, I'll try to isolate the issue.SSmolak wrote:It crashes very often even using old node styleaoktar wrote: 2023 and Octane is fragile for now! I'll try to fix the issue. That's coming from used library for new node graphics.
I sent you PM with material that cause immediately crash in node editor.aoktar wrote: It's not matter what you do, I don't mean to use the new style. It's causing complete unstability. Just don't use the plugin if you need stability, I'll try to isolate the issue.
