Cinema4D version 2022.1-XB3-(R4) (Experimental) 23.09.22
Hi all,
This is the latest experimental plugin build based on experimental 2022.1-XB3 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching OctaneRender® 2022.1 XB 3.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Please note that because of the active development, there are several limitations outlined below.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
2022.1-XB3-R4 plugin revisions
  • Fix: ImageTexture's filename issues on copy/paste
  • Fix: Checking the resolution for Locked resolution and changes in runtime
  • Fix: some problems on compare image
  • Fix: broken AO environment texture
  • Fix: use sub-material checkboxes for layered material
2022.1-XB3-R3 plugin revisions
  • Fix: ignore unused materials
  • Fix: Imagetiles operation
  • Fix: priority range for clipping material
  • New: curvature visibility parameter in Octane tag
  • Fix: slow texture menu on scenes with lot of animated ImageTexture and faster asset collection
2022.1-XB3-(R2) plugin revisions
  • Fix: broken sub parameters for some AOVs when they are used in AOV compositor
  • Fix: Render error when OCIO selected with an empty string in ImageTextures
2022.1-XB3 plugin revisions
  • Added first 2022.1 support for M1 Macs
  • Scatter object: New WIP distribution mode POISSON and fix for distribution issues with old Surface mode.
  • Several fixes
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-26/R2023)
https://render.otoy.com/customerdownloa ... R4_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-26/R2023)
macOS 12.3.1(M1 cpu) BUILD (R25-R26/R2023)
https://render.otoy.com/plugindownloads ... R4_OSX.zip
Please note the macOS build below will only work correctly on macOS 12.3.1 and newer, and only on Apple Silicon.
Also node previews are working with new style. Switch to old style and use from Node editor menu until we fix it.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
About Mac M1 native version, remember to disable the Open using Rosetta option in the Info of the Cinema 4D.app:
You also need to allow the c4doctane plugin and library in System Preferences/Security and Privacy panel, and restart C4D a couple of times.
Finally, you need to go to c4doctane Setting/Nodes, and disable the New style option, or material preview doesn't work in node editor:
It is a Prime free version, so every Mac Octane users with Apple Silicon GPU can install it.
Happy Mac GPU rendering!
ciao,
Beppe
841131100
Why does it show white when the ACES tone mapping is turned on?
ACEs Tone Mapping
LV - HDRI Environment - Visible Editor, Renderer Off - It turns white.
LV - HDRI Environment - Clipping Dark Area.
eyeonestudio
elsksa wrote:
841131100 wrote:Why does it show white when the ACES tone mapping is turned on?
ACEs Tone Mapping
You'd have to provide more information.
If that's what I think it is, it's the expected result.
The ACES (SDR RRT+ODT sRGB) doesn't eradicate maximum white level, and the environment texture is a "constant value", unaffected by shading. Unlike surface reflectance.
The description of the new features is lacking.
We didn't have this feature before, so we didn't have any problems.
Something is wrong with the input or output levels in OCIO. (My guess. I'm not developer)
As long as the HDRI is built to have adequate brightness, there is no problem.
Here is My testing
ACEs Tone Mapping
---> go to Settings > Env > set Lum Mult 1 / set 2.0% or more gray Color (
ACEs Tone Mapping
---> Image Texture Node --> Range Node(custom texture) : input min set -0.005 or lower
EDIT - Still Testing
Image Texture > Color Space > OCIO > Octane Console Error
"Failed to build OCIO input transform: Source color space "" not found "
==> Clean up OCIO Variable/ACES config. Reconfigured OpenColorIO-Config from Github
==> no error. However, more testing is needed.
==> This is not a bug. Enter the OCCIO profile and it works. However, the material preview doesn't update correctly.
PS. It has nothing to do with ACES Tone Mapping bugs.
eyeonestudio
elsksa wrote:
eyeonestudio wrote: The description of the new features is lacking.
Have a look at: https://www.elsksa.me/scientia/cgi-offl ... management even if it's showing Standalone GUI, it's universal and applies to Octane plugins.
eyeonestudio wrote: Something is wrong with the input or output levels in OCIO. (My guess. I'm not developer)
OCIO is just OCIO.
It has nothing to do with the HDRI light data, as long as it's a properly created HDRI file, which is an other story and unrelated to all the rest.
eyeonestudio wrote: -->Failed to build OCIO input transform: Source color space "" not found
It is mentioned in the page from the first link, no need for any OCIO configuration file when using that new "checkbox option". However, anything ACES will yield a broken imagery, and therefore, ACES has to be avoided. Solely relatively to other long-standing native options from the Camera Imager, it's a negligible improvement.
Thank You...
We are looking for bugs. Because we want the C4D plugin to evolve further.
We are talking about ACES Tone Mapping introduced in C4D Camera Imager.
There is no problem with Standalone-Imager-ACES Tone Mapping.
eyeonestudio
elsksa wrote:You're welcome. However, you misunderstood me. Both are the same.
There shouldn't be any OCIO configuration file loaded when using that single-checkbox ACES option from the Camera Imager. No OCIO loaded in the system or Octane, should result in no OCIO warning or error.
I've tested all options before and decided it's a bug.
It's probably still under development, so it won't be perfect.
Please let me know if I missed anything.
jayroth2020
I believe the issue is that you have the have the Colorspace switcher set incorrectly in your Live Viewer. It should be set to OCIO:<sRGB>. Please try that. With the settings you have shown, the HDR/sRGB setting will NOT show the correct result, as your screen capture indicates.
divasoft
[*] Scatter object: New WIP distribution mode POISSON and fix for distribution issues with old Surface mode.
SSmolak
LiveViewer moving, rotating is incredible slow compared to 2021 version. In 2021 I had CameraImager min. display samples set to 20, the same scene in 2022 needs to be set to 5 to make the same viewer speed. Subsampling also has much less impact to increasing speed.
And yes, something wrong is with built-in ACES :
Still freeze during rendering if buffer type is set to 16 bit and color space to sRGB.
RTX works only in LiveViewer not for final render.
SSmolak wrote:LiveViewer moving, rotating is incredible slow compared to 2021 version. In 2021 I had CameraImager min. display samples set to 20, the same scene in 2022 needs to be set to 5 to make the same viewer speed.
It's not related with navigation speed. Interaction performance is same, but there may be some slowness for first 20 samples if you're using min. disp. samples. Why do you use it also?
Also I know the issue. Absolutely you don't need to use 16/8 bits for 8bit or sRGB outputs. Just go with working buffer until I fix it.
How can you be sure that's not working? I see that's working.
