OctaneRender® 2022.1 XB 3
J.C
Despot wrote:Where are the new PostFX changes/additions that were promised for 2022 ? Are they still going to make it ?
Not expecting an answer from any Otoy employee here as my last two comments/questions were just ignored... ;)
J
Vectron was more important ;)
System – Windows 11
karl
J.C wrote:
bepeg4d wrote:
J.C wrote:When toggling realtime button rendering the rendering goes 150% slower.
please note that Real Time works only with 1x GPU.
So if you have a multi GPU machine, this is expected.
ciao,
Beppe
There is no speed difference when it is on or off. The render times are the same using 1x GPU.
The purpose of real time mode is to improve the frame rate and latency of the viewport in order to improve responsiveness/interactivity when moving the camera. If you're just starting the render and waiting for it to complete, real time mode will not help. We've already made the renderer as fast as possible at doing that :)
(Note 1: In some circumstances real time mode may give a small improvement in overall render time due to less total time spent getting images on screen instead of rendering; this depends on the scene and is likely to be a very small effect.)
(Note 2: Real time mode disables various features, such as multi-GPU/network rendering, adaptive sampling, cryptomatte passes, so cannot be used in all situations.)
(Note 3: In this experimental build the real time feature is not yet complete; the Brigade features are yet to come. That should significantly improve the experience of real time mode, but will still not decrease overall render times.)
coilbook
Hi Karu,
Can you please add a checkbox next to AI light set all lights sampling rate to 1? That way if we have noise problem with manual sampling rate per light we can try ai light and default all lights in the scene sampling rate to 1 including light textures Thanks
J.C
john_otoy wrote:
Have you tried enabling kernel > AI light, then setting all your light's sampling rate back to a default of 1.0?
The information about AI light and default light sampling rate relationship should be in manual. Could you update it please?
System – Windows 11
J.C
I guess the term "real time mode" can be quite misleading while it's not giving any difference in render time. I would suggest changing the name to "Low viewport latency" or similar.
System – Windows 11
karl
coilbook wrote:Hi Karu,
This is not my area of expertise; maybe someone else can chime in on any plans in this area.
Kalua
Maybe you should make a wish on the "Features Request" page.
C4D 2025.1.1 Octane 2026.1 v1.8.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Octane User since V1 Beta
J.C
"Features Request" for a proper description of Octane features in the manual? Are you kidding me?
System – Windows 11
Kalua
I misread your message. My apologies. You are right. Not kidding.
J.C
but after a second thought I think this might be a good option to make it a "Feature request". Maybe somebody will notice this.
System – Windows 11
