Cinema4D version 2022.1-XB2-(R2) (Experimental) 23.07.2022
SSmolak wrote:This build is still not compatible with latest NVidia Studio drivers 516.59 - connecting, reconnecting Image Texture nodes ( procedural ones too ) or changing Mix value in material node cause huge CPU delay compared to previous Studio drivers. Live Viewer is locked for 5-8 seconds. Even disabling nodes cause delays.
Attached video.
I think that this is caused by caching because reconecting last used node tree doesn't generate such freeze. I tried disabling caching in Nvidia driver and Octane settings without success.
Please, perform a clean installation of 512.59 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 7604/en-us
To perform a clean installation, please follow these steps:
ciao,
Beppe
SSmolak
bepeg4d wrote: Please, perform a clean installation of 512.59 Nvidia Studio driver:
ciao,
Beppe
I did this two times using DDU too. I'm go back and using 512.96 and everything is fine now. there was something changed in 516.59.
EDIT : ah I see that you write about earlier 512.59 driver version. So the newer ones are not tested ?
divasoft
Hello, I'm trying out the new version.
Tell me please, why can't I save any file format other than exp through octane?
If I choose tiff or png in this place, then octane simply does not save anything.
divasoft wrote:Hello, I'm trying out the new version.
It saves here, what are you saving by render AOVs? You have "denoised beauty" checked, any other passes(AOVs)? Please put your scene here.
eyeonestudio
"Edge Tint" doesn't seem to work. And can't connect rgb-texture even in node editor.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio wrote:"Edge Tint" doesn't seem to work. And can't connect rgb-texture even in node editor.
The attachment 2022-07-21_113350.jpg is no longer available
it is working here:
And if you press the Tex button, you can use any kind of texture node, even if the connection/pin is not displayed:
ciao,
Beppe
eyeonestudio
Volume Builder(Fog) + Octane Volume Medium --> O.K
Volume Builder(Fog) + new Standard Volume --> Density channel is not recognized. (also TFD)
New Standard Volume is good feature.
I'd love to be able to use it with Volume Builder(Fog).
If this is possible, it can do a lot. Because a texture can be used for Standard Volume - Density.
** It's DEV :)
eyeonestudio
it is working here:
ciao,
Beppe
Ya. 2021.1.5 is OK. Not 2022.1.XB2.R1 (windows10, R26)
eyeonestudio wrote: Ya. 2021.1.5 is OK. Not 2022.1.XB2.R1 (windows10, R26)
One command seems like accidentally deleted by me in the software. I'll fix it.
GXGsynth
something seems to have broken between C4D and Standalone versions re: Toon shader outlines, a project started in C4D 2022.1 XB1-R3 displays incorrectly in 2022.1 XB2-R1, so I opened it in standalone 2022.1 XB 1 and found that it was completely disregarding all Toon Outline values and adding the default Black 0.3 Outlines, and when I set that back to 0, it looks correct again in standalone, but I cannot get C4D XB2-R3 to do anything with Outlines whatsoever:
displays correctly in C4D XB1-R3
incorrect in C4D XB2-R1, outlines cannot be changed
edit in standalone reveals added default black 0.3 outlines
Return to “Releases”
