Cinema4D version 2022.1-XB2-(R2) (Experimental) 23.07.2022
Hi all,
This is the latest experimental plugin build based on experimental 2022.1-XB2 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching OctaneRender® 2022.1 XB 2.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Please note that because of the active development, there are several limitations outlined below.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
2022.1-XB2-(R2) plugin revisions
  • Fix: Volumebuilder works with Standard Volumes now.
  • Fix: Some broken toon material parameters
  • Colorkey and Adjustment nodes added
  • Some visual fixes for nodes UI
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-26)
https://render.otoy.com/customerdownloa ... R2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-26)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
y81r
Octane initalizes now also Aov output is saveing again in this version
Thank you!
divasoft
Hi Ahmet.
About the scatter. Maybe you don't need to invent and write new code? You can just take what the main development team has already done in standalone and just implement it, as you implement everything else in the integration. Because the standalone scatter works both fast and well.
y81r wrote:Octane initalizes now also Aov output is saveing again in this version
Thank you!
Enjoy it!
BCres
I click on the link to download the 2022.1-XB2 file and it states "I am not authorized to view that forum." My subscription is current and paid up through next year.
**Nevermind, I got in through my Downloads page in my account.**
divasoft wrote:Hi Ahmet.
Maybe but I don't love to put my work to trash. You may understand me if you think that's one of the first scatters in the renderers with this capability. Also adding a mode for Octane scatter will cause to loose the some C4D features for scatter. As no viewport dummies/no mograph effectors/no vertexmaps/.... Anyway we'll check it!
And share your scene, our scatter should be fine in your case. I need to see what's your problem.
divasoft
Yes, sure, your scatter is very good compared to others.
Scene example: https://disk.yandex.ru/d/nZzlUAgIQKaUGg
SSmolak
This build is still not compatible with latest NVidia Studio drivers 516.59 - connecting, reconnecting Image Texture nodes ( procedural ones too ) or changing Mix value in material node cause huge CPU delay compared to previous Studio drivers. Live Viewer is locked for 5-8 seconds. Even disabling nodes cause delays.
Attached video.
I think that this is caused by caching because reconecting last used node tree doesn't generate such freeze. I tried disabling caching in Nvidia driver and Octane settings without success.
freeze.zip
(462.82 KiB) Downloaded 250 times
bullet0830bs
When will OctaneRender 2022.1 XB 3 C4DPlugin be released?
I'm looking forward to brigade! :D
NNVFX
jiabangshou104
Apparently, an error is displayed when ACES tone mapping is activated.
