How to mix two displacement maps?
Houdini Integrated Plugin
Admin_KeenSWH
Hey magicians, I want to mix grass and rocks materials within one shader based on a vertex float attribute that I got, and those grass/rock materials mix nicely except displacement maps. Is there a way to mix two displacement maps within one shader? I tried using Material Mixer node and Mix Texture node but with no luck. Any help would be much appreciated!
Here's what I tried but it didn't work:
Thanks in advance!
MY CONFIG:
OS: Win 10
Video Card: 2070 RTX
VRam: 8Gb
Geforce Driver: 516.69
OctaneRender Standalone 2021.1.4
OctaneRender Houdini plugin version 2021.1.5.0 (May 18 2022)
Houdini FX Version 19.0.622
galleon27
You can't mix two displacement maps using Displacement node. You need to use Vertex Displacement and Vertex Displacement mixer.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Admin_KeenSWH
galleon27 wrote:You can't mix two displacement maps using Displacement node. You need to use Vertex Displacement and Vertex Displacement mixer.
Oh this looks good! But can I got a couple of questions.
1. Can I feed my usual grayscale displacement maps into Vertex Displacement node?
2. It looks like I should subdivide my geometry hugely to get result hires enough which loads GPU a lot. Attaching the comparison between vertex displacement vs. usual displacement.
Could you please share a scene so I could check it?
MY CONFIG:
OS: Win 10
VRam: 8Gb
galleon27
You can use displacement maps.
Just turn on auto-bump and you'll be good. If you need more details, you will have to subdivide the geometry. I suggest to read the manual to learn the differences between the two. https://docs.otoy.com/StandaloneH_STA/S ... cement.htm
displacement.zip
(64.44 KiB) Downloaded 151 times
Admin_KeenSWH
Thanks for the response and providing this info.
But for some reason the scene opens with errors. Can you please check screen in the attachment?
p.s. My config is in the signature.
MY CONFIG:
OS: Win 10
VRam: 8Gb
juanjgon
The scene probably comes from an earlier plugin version. Usually, it is safe to ignore these warnings, but some render target settings could be reset to the default values.
Admin_KeenSWH
juanjgon wrote:The scene probably comes from an earlier plugin version. Usually, it is safe to ignore these warnings, but some render target settings could be reset to the default values.
Oh I see, ok, thanks for the heads up!
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Ok, having downloaded your scene, I did my own tests following your workflow and I still can't understand why it doesn't work for me..
I created Attr. VOP with float attribute cow it has 0 and 1 float values in relevant black/white areas (I double-checked it using visualizers). I plug it to mixing amount and still it doesn't work.. What am I doing wrong?
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Upd. Ignore - me stupid. I just forgot to add cow to Octane's attribute field on that Grid's geo.
MY CONFIG:
OS: Win 10
VRam: 8Gb
Admin_KeenSWH
Hmm.. the only problem with this approach though is that now I can't seem to make displacement push the geometry outwards - it's very flat looking like a regular bump now.. Can I ask you to check my simple scene in the attachment please?
Maybe I'm somehow misusing the Gradient node attached to Float Vertex Attr?
Looks more like a bump :/
Mix_Displacements.zip
(5.77 MiB) Downloaded 152 times
MY CONFIG:
OS: Win 10
VRam: 8Gb
Return to “Houdini”
