OctaneRender® 2022.1 XB 1
vurt
abstrax wrote:
Raoul wrote:roadmap:
"Metal and CUDA network render interoperability"
This is the #1 issue for us being able to continue using octane. Currently stuck on high sierra till this singular feature is developed.
just curious if theres any news on an ETA for this?
We have started working on it, but it won't be in 2022.1 and is planned for 2022.2. It's a big change.
we are also waiting for that.
But at least, the same version is coming to Metal, since currently having 2020 on Mac and 2021 on PC is useless for a Mac part
nuno1980
At photon tracing kernel, "allow caustics" enabled for glossy or mix or... material is bugged because the caustics on any glossy are creating by both pathtracing (PT) and PPM (progressive photon mapping). PT using will be removed for allow caustics of glossy, mix... material at photon tracing kernel in next version XB. ;)
LASTEST EDIT: see screenshot about abnormal strong noises (PT method inside of photon tracing):
--> download
test - allow caustics on all glossy materials.orbx
(37.19 KiB) Downloaded 251 times
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
J.C
Added real-time mode (lightning button on render viewport). In this mode, if possible, the film buffer is never moved between the host and the device. This means that compositing has to be done on the GPU, and it also enables a "real-time" display, which will display rendered images faster
This does not speed up the render or anything. Is it something else to be enabled to make it work?
A device in preferences is selected and enabled.
System – Windows 11
pegot
I just tried this feature today. My assumption is that it acts like the priority mode in that it makes the viewport more responsive? At least that is what it appeared to do for me though I did not test on an overly heavy scene.
If that is indeed the case I have a question regarding multiple GPU’s. Setting it up in device preferences allows for only one GPU - like priority mode. So when using it should we activate it for the same GPU we have priority mode set to or our fastest GPU?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
haze
This is one half of the full real-time rendering system. XB2 will have Brigade as part of it, which will give you high quality frames faster. Having the film buffer on GPU is a requirement for this to work. That allows us to tonemap and display images faster, so you should at least see the viewport being more responsive this way. If you do not, please send us an example scene so we can figure out what's going on, it could be a bug.
EDIT: we need more time for Brigade, so it will not be in XB2 as I stated above.
J.C
On my PC I don't see any speed difference weather it is on or off. No matter the scene I use.
System – Windows 11
Jolbertoquini
Hi Dev Team,
I was wonderring if we will get the "Parallax Occlusion Map" soon? as we are using the OSL script made one but shadows are not supported I was wondering if there any chance to have this feature supported or will be just add as new projection node and won't support shadows like osl script version here on the forum.
Thank you in advance for the reply.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Kalua
Jolbertoquini wrote:Hi Dev Team,
Best,
JO
True! This is a really great thing!
I made a feature request for it with the same issues reported. Feel free to vote for it:
https://render.otoy.com/requests/?qa=56 ... splacement
Regards,
Octane User since V1 Beta
Jolbertoquini
Best,
JO
Regards,
Yes, I already voted a while ago but as you can see at link because passed the release is not valable anymore so this why the question for the dev team.
JoGo23
Hi, can you confirm that OctaneRender® 2022.1 XB will eventually work with AMD GPUs other than the ones from Apple ?
