Hi HHbomb,HHbomb wrote:Hi NZ
My scene works fine for me too...
I need to create my scene, save, close then open. And boom it works... (?)
I reset prefs but it seems to make no change.
I create another scene, and after close and reload, it works fine, except that when I move object or scroll timeline multimaps are affected to different polys ( maps change on polys )
Strangely, your Multi-Texture_samples file works perfectly without any problem...
ps : I uncheck Quickmode because I don't remember when and what something didn't update with QM checked.
Thanks for the clarification.
That's right, there seems to be some update missing in some case.
While assigning the multi-texture to new objects, the current steps are:
-click Refresh objects, and use the 'Fix' buttons to add and setup the octane modifier.
-Then, when choosing 'Material ID' attribute on the objects (context menu),
a viewport update is missing..
So you currently need to press the 'Update render geometry' button in Octane viewport..
That should be enough, there should be no need to save and reload the scene..
You could also try the 'Rebuild scene' button, or close and re-open the Octane viewport..
The workflow should be improved in the next release.
