any example to show what are talking about?SSmolak wrote:Possible issue with isoparms display color in C4D viewport line display mode - they are always totally bright no matter of material color. Only way to change their color is to set object to custom display color. There is no way to change their default color in C4D editor color preferences.
Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
It may be about your scene setup or content. Have you checked with previous builds?KeeWe wrote:Is anyone working with S26 and octane on an project based level? Rendering to PV seems very buggy, freezes c4d pretty often. But I can't tell if it's an octane/c4d problem. Does anyonye have similir or completely different experiences?
It is not related to Octane OGL preview of materials. This can be controlled in C4D preferences - scheme colors - editor - Spline/Nullaoktar wrote:any example to show what are talking about?SSmolak wrote:Possible issue with isoparms display color in C4D viewport line display mode - they are always totally bright no matter of material color. Only way to change their color is to set object to custom display color. There is no way to change their default color in C4D editor color preferences.
I think I found a small bug:
Unchecked "Custom AOV" in Composite shader shows on custom AOV layer.
Regards,
Regards,
C4D 2025.1.1 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Hi Ahmet,
having some trouble with this and the previous version ...
My machine freezes after a couple of frames rendering and needs a complete restart. Even if working with LV it crashes after some time.
I tried different things to solve this without success:
- activated my 1080TI only for having more GRAM available
- changed NVidia settings of C4D like described here: https://www.youtube.com/watch?v=injfhCVLwBI
- confirmed that the TdrDelay settings are at a value of 60
I am using R26 with the latest version of plugin & standalone with NVidia Studio driver 512.59
BTW: the crashes are happening when using Redshift, too!
Any hints what I could further do?
Ron
OctaneLog:
Ron
OctaneLog:
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Hi Ron,
the plugin is loaded from Dropbox, not good for stability: Please install it correctly in C:\Program Files\Maxon\Cinema 4D R26\plugins\c4doctane (You have to create the plugins folder in lowercase!), and report back, thanks.
ciao,
Beppe
ciao,
Beppe
Hi Bepe,bepeg4d wrote:Hi Ron,
ciao,
Beppe
thanks for the hint. I did as you advised but without success. C4D is crashing even with simple scenes after a while working.
Maybe its a driver related issue?
Which driver is known to be stable with this plugin version?
Ciao
Ron
But there is also issue while using C4D Transform Manager - for example changing Octane Light rotation here updates after 15 second or more, doing the same using rotation in viewport updated in realtime.aoktar wrote:I don't suppose this is new behavior for this build. And I don't think there's much to do. It can give different problems if I try to play with that. Things are extremely complicated in detection parts and sometimes no real solutions.SSmolak wrote:Please see problem with updates. This window is generated by capsule nodes. Also normal geometry has problems too. Making undo after geometry changes never update.
Hi Ron,Ron wrote: Hi Bepe,
Ciao
Ron
please write to help at otoy dot com, asking for me, I can investigate more deeply.
ciao,
Beppe
OK - I will do but before I will do a clean install of old driver version 472.84 to see if the behavior is still the same.bepeg4d wrote:
Hi Ron,
ciao,
Beppe
