Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
SSmolak wrote:Possible issue with isoparms display color in C4D viewport line display mode - they are always totally bright no matter of material color. Only way to change their color is to set object to custom display color. There is no way to change their default color in C4D editor color preferences.
any example to show what are talking about?
KeeWe wrote:Is anyone working with S26 and octane on an project based level? Rendering to PV seems very buggy, freezes c4d pretty often. But I can't tell if it's an octane/c4d problem. Does anyonye have similir or completely different experiences?
It may be about your scene setup or content. Have you checked with previous builds?
SSmolak
It is not related to Octane OGL preview of materials. This can be controlled in C4D preferences - scheme colors - editor - Spline/Null
Kalua
I think I found a small bug:
Unchecked "Custom AOV" in Composite shader shows on custom AOV layer.
Regards,
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Ron
Hi Ahmet,
having some trouble with this and the previous version ...
My machine freezes after a couple of frames rendering and needs a complete restart. Even if working with LV it crashes after some time.
I tried different things to solve this without success:
- activated my 1080TI only for having more GRAM available
- changed NVidia settings of C4D like described here: https://www.youtube.com/watch?v=injfhCVLwBI
- confirmed that the TdrDelay settings are at a value of 60
I am using R26 with the latest version of plugin & standalone with NVidia Studio driver 512.59
BTW: the crashes are happening when using Redshift, too!
Any hints what I could further do?
Ron
OctaneLog:
c4doctanelog.txt
(28.64 KiB) Downloaded 236 times
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Hi Ron,
the plugin is loaded from Dropbox, not good for stability:
Please install it correctly in C:\Program Files\Maxon\Cinema 4D R26\plugins\c4doctane (You have to create the plugins folder in lowercase!), and report back, thanks.
ciao,
Beppe
Ron
bepeg4d wrote:Hi Ron,
ciao,
Beppe
Hi Bepe,
thanks for the hint. I did as you advised but without success. C4D is crashing even with simple scenes after a while working.
Maybe its a driver related issue?
Which driver is known to be stable with this plugin version?
Ciao
Ron
SSmolak
aoktar wrote:
SSmolak wrote:Please see problem with updates. This window is generated by capsule nodes. Also normal geometry has problems too. Making undo after geometry changes never update.
I don't suppose this is new behavior for this build. And I don't think there's much to do. It can give different problems if I try to play with that. Things are extremely complicated in detection parts and sometimes no real solutions.
But there is also issue while using C4D Transform Manager - for example changing Octane Light rotation here updates after 15 second or more, doing the same using rotation in viewport updated in realtime.
Ron wrote: Hi Bepe,
Ciao
Ron
Hi Ron,
please write to help at otoy dot com, asking for me, I can investigate more deeply.
ciao,
Beppe
Ron
bepeg4d wrote:
Hi Ron,
ciao,
Beppe
OK - I will do but before I will do a clean install of old driver version 472.84 to see if the behavior is still the same.
Return to “Releases”
