Cinema4D version 2021.1.4-(R4) (Stable 2021) 21.04.2022
Please see problem with updates. This window is generated by capsule nodes. Also normal geometry has problems too. Making undo after geometry changes never update.
- Octane_updates.zip
- (3.36 MiB) Downloaded 209 times
also :
Force Updates resolve this
- Octane_upd.zip
- (1.96 MiB) Downloaded 205 times
There's a behavior change, I can't remember why done. MAybe to fix another usages of particle engine, and it covers the scatter object also. You can get expected results if you use it like this.wangdanyang1120 wrote:I met a problem.
After version 2021.1.1-R3.Surface Type of Octane Scatter,can't scale with object.
- a1.jpg (5.23 KiB) Viewed 3629 times
I don't suppose this is new behavior for this build. And I don't think there's much to do. It can give different problems if I try to play with that. Things are extremely complicated in detection parts and sometimes no real solutions.SSmolak wrote:Please see problem with updates. This window is generated by capsule nodes. Also normal geometry has problems too. Making undo after geometry changes never update.
Try this test build, I've made some revision for scatter's clones. They use the global matrix for now.wangdanyang1120 wrote:I met a problem.
https://render.otoy.com/customerdownloa ... st-win.rar
- wangdanyang1120
thank you aoktar.aoktar wrote:Try this test build, I've made some revision for scatter's clones. They use the global matrix for now.wangdanyang1120 wrote:I met a problem.
This beta solves the problem to some extent, but if the object scaling is changed, the rendering must be restarted.
If there is a scale animation, there are still some problems.
- Untitled 1.zip
- (22.44 MiB) Downloaded 191 times
Since scatter object is working different, that means there's not any generated virtual objects. This causes no dirty bits for object, so detecting this kind of change requires a complicated iteration and comparison. You can simply key something on top level of clone object. Then it will ping the engine for updates.wangdanyang1120 wrote:thank you aoktar.aoktar wrote:Try this test build, I've made some revision for scatter's clones. They use the global matrix for now.wangdanyang1120 wrote:I met a problem.
- luminouspowerhouse
Ahmet thank you for rolling out S26 build so fast!
Possible issue with isoparms display color in C4D viewport line display mode - they are always totally bright no matter of material color. Only way to change their color is to set object to custom display color. There is no way to change their default color in C4D editor color preferences.
Is anyone working with S26 and octane on an project based level? Rendering to PV seems very buggy, freezes c4d pretty often. But I can't tell if it's an octane/c4d problem. Does anyonye have similir or completely different experiences?
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
