I am using a Layered Material with 3 Submats. I wired a single Displacement node into each of the 3 Mats but it is not recognized by Octane. Displacement is not showing. Is it not working with Layered Mat?
Layered material with displacement?
- jayroth2020
The Cinema 4D Layered material is not supported. You can use the Composite Material instead, though you would need to add a Bake Image node before the Displacement node to Texture displacement. For vertex displacement, use the Vertex Displacement Mixer node to blend several displacement maps together.
