Cinema4D version 2021.1.2-(R2) (Obsolete 2021) 18.02.2022
Kalua
Hi, Aoktar
Latest version is very smooth.
Until recently I noticed the "Noise4D", which is pretty awesome! I see there are some differences compared to the "Noise" node.
I have been playing with it lately. I noticed, "transform node" doesn't work with this particular node right?
Regards,
Noise4D with no Transform node works great
Noise4D with Transform node doesn't work
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
jayroth2020
Try adding a projection node.
Kalua
jayroth2020 wrote:Try adding a projection node.
Yes!
It did the job!
Thank you, jayroth2020.
Regards,
jayroth2020
You're welcome!
divasoft
Hello, have you any idea to fix this issue?
I have a plane with opacity (texture) in material and it intersect ball. I get tiny frinde in intersection place.
I tried to change priorities in materials, tried to use rayswitch to fix it, changed grayscale texture to rgb. Unsuccessfully.
VladaStevanovic
divasoft wrote:Hello, have you any idea to fix this issue?
Man you are using Octane 2020.2.5 R3 , this topic is for 2021 octane right?
You want to fix a physically correct thing , Your transparent plate has a reflection at the edges, which means that the same reflection will appear in the intersection edges
Doesn't that make sense to you?
Separate edges, problem solved.
divasoft
There should not be any reflections at the intersection of the plane and the ball, because this area of the plane is completely transparent.
Kalua
Have you tried:
- Play with Ray epsilon values
- Play with Diffuse, Specular and Scatter depth values;
- Nested dielectrics ticked off
- Alpha shadows
- Fake shadows
Regards,
SSmolak
Please see how is wrong with AOV system. There are some issues.
Generally I want to add/mix Diffuse Indirect ( masked by Triplanar Y- from Wall Material ) with Beauty. Masked Indirect by Triplanar works fine but mixing this with Beauty no. Also Triplanar AOV should give black/white mask. There is need to use Range AOV but after that there is visible outline on mask border.
AOV.zip
(137.05 KiB) Downloaded 199 times
HTK421
This UI bug in the node editor has been around for a long time.
Many of the nodes are still not associated with a filter.
Return to “Releases”
