Better quality using render region?
atoyuser1
this is odd, I'm getting better results from emissive renders when enabling render region:
This is at 512 samples:
Render
Render
render region
render region
no odd, it's not producing or re-rendering the parts. Never stops at max-samples if you could notify. It's just for working on small areas with less time.
atoyuser1
aoktar wrote:no odd, it's not producing or re-rendering the parts. Never stops at max-samples if you could notify. It's just for working on small areas with less time.
Ah I see.
Is there a way to improve this emitted light without rendering at thousands of samples?
I think I asked similar question here: viewtopic.php?f=30&t=78740&p=406766#p406766
I've tried adaptive sampling and denoiser, but I am on Octane PR11, so I think it's not working for that version
atoyuser1
elsksa wrote:
atoyuser1 wrote: Is there a way to improve this emitted light without rendering at thousands of samples?
Hi, in this following link, there are some tips and recommendations that could help: https://www.elsksa.me/scientia/cgi-offl ... r-settings
Thanks Elska, I read that and I also tried your tips from this thread where you suggested using a GaussianSpectrum. I still cannot get a acceptable render from 512 samples:
Noise from emitted light
I attached my files in case you want to have a look
LightTest-v01.orbx
Orbx file
(9.66 MiB) Downloaded 142 times
LightTest-v01.c4d.zip
C4D file
(101.9 KiB) Downloaded 137 times
atoyuser1
I can get round this using 10,000 samples and adaptive sampling. 42 seconds:
Adaptive sampling. 10,000 samples
LightTest-v02.c4d.zip
(79 KiB) Downloaded 99 times
Surely there is a better way? Unfortunately I don't have the luxury of the denoiser
