I tried to start-up with the default interface and its ok, if I try to recall my personal UI with octane panels it crashes.aoktar wrote:@19Nik90,
could you try with clean startup layout without having any Octane dialog?
Cinema4D version 2021.1.1-R3 (Previous stable) 01.02.2022
Can you send me your personal UI as layout file?19Nik90 wrote:I tried to start-up with the default interface and its ok, if I try to recall my personal UI with octane panels it crashes.aoktar wrote:@19Nik90,
Yeah no problem, attached my personal Layout file. Thanxaoktar wrote:Can you send me your personal UI as layout file?19Nik90 wrote:I tried to start-up with the default interface and its ok, if I try to recall my personal UI with octane panels it crashes.aoktar wrote:@19Nik90,
- Dual Monitor 01.zip
- Layout
- (29.01 KiB) Downloaded 264 times
Thank you, Aoktar!aoktar wrote:3rd build(R3) is out for using. Enjoy it!
So far it runs smoothly on R25.117!
Regards,
Octane User since V1 Beta
- LOVEXMEDIA
Hello!
Just wanted to share that the issue I was having with the comment node no longer occurs in the newest release! 2021.1.1-R3
Very excited to use this now and clean up some older materials!
Thank you for you and the teams hard work with the Cinema4D side of things Aoktar!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
Hi, first time setting up on a PC. I get this error when trying to run OctaneRender Studio 2021.1.1 standalone:
I'm using:
Version 10.0.19044 Build 19044
Processor AMD Ryzen 9 5950X 16-Core Processor, 3401 Mhz, 16 Core(s), 32 Logical Processor(s)
GPU AMD Radeon RX 6900 XT
Also the Cinema 4D plug doesn't launch, but I'm guess this is related
EDIT: Just found the FAQ oh boy
I'm using:
I found that my latest revisions about icons that was causing crashes on Octane Dialog. Now fixed and replaced the links with new build.19Nik90 wrote: Yeah no problem, attached my personal Layout file. Thanx
Perfect! Now it works! Thank you very muchaoktar wrote:I found that my latest revisions about icons that was causing crashes on Octane Dialog. Now fixed and replaced the links with new build.19Nik90 wrote: Yeah no problem, attached my personal Layout file. Thanx
