Cinema4D version 2021.1.1-R3 (Previous stable) 01.02.2022
19Nik90
aoktar wrote:@19Nik90,
could you try with clean startup layout without having any Octane dialog?
I tried to start-up with the default interface and its ok, if I try to recall my personal UI with octane panels it crashes.
Can you send me your personal UI as layout file?
19Nik90
Yeah no problem, attached my personal Layout file. Thanx
Dual Monitor 01.zip
Layout
(29.01 KiB) Downloaded 272 times
Kalua
aoktar wrote:3rd build(R3) is out for using. Enjoy it!
Thank you, Aoktar!
So far it runs smoothly on R25.117!
Regards,
Octane User since V1 Beta
LOVEXMEDIA
Hello!
Just wanted to share that the issue I was having with the comment node no longer occurs in the newest release! 2021.1.1-R3
Very excited to use this now and clean up some older materials!
Thank you for you and the teams hard work with the Cinema4D side of things Aoktar!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
feels
Will Octane for C4D ever be able to access hair UVs / per-curve width attributes from XGen and other grooming tools?
atoyuser1
Hi, first time setting up on a PC. I get this error when trying to run OctaneRender Studio 2021.1.1 standalone:
I'm using:
Version 10.0.19044 Build 19044
Processor AMD Ryzen 9 5950X 16-Core Processor, 3401 Mhz, 16 Core(s), 32 Logical Processor(s)
GPU AMD Radeon RX 6900 XT
Also the Cinema 4D plug doesn't launch, but I'm guess this is related
EDIT: Just found the FAQ oh boy
19Nik90 wrote: Yeah no problem, attached my personal Layout file. Thanx
I found that my latest revisions about icons that was causing crashes on Octane Dialog. Now fixed and replaced the links with new build.
19Nik90
Perfect! Now it works! Thank you very much
moebius
Are you gonna fix Cryptomatte: Instance? Last version it worked was c4doctane_2021.1_R6
now it crashes at rendering in Picture-Manager
thanks for all the work
Return to “Releases”
