Cinema4D version 2021.1.1-R3 (Previous stable) 01.02.2022
Hi all,
This is the newest stable plugin build based on 2021.1.1 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching Standalone 2021.1.1.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
2021.1.1-(R3) plugin revisions
- Fix: wrong results with MoGraph shader for some cases
- Added missing 'Look' parameter for image save dialog
- Fixed: removing the 'intersection material' from the 'clipping material' when 'remove unused materials' command is used
- Some fixes on "custom texture" nodes.
- Fix for wrong instance color with multi-instances when cloner's grid mode is sphere/cylinder.
2021.1.1-(R2) plugin revisions
- Added "Comment" node for node editor
- Minor fixes on AOV related parts
- Added Light Mixer node under render AOV outputs.
2021.1.1 plugin revisions
- Some minor fixes on AOV topics and added new crypto AOVs.
- Note that "user_instance_id" is causing a crash, will be fixed on next SDK.
2021.1.1 Renderer changes
Added Cryptomatte AOVs for mattes based on the render layer, user instance ID and geometry node name of an object.
Brought back the option "Emulate old volume behaviour" to the kernel nodes.
Overhauled the way how render work is distributed to local and remote GPUs: The main idea is to reassign already assigned but unfinished work to available GPU when there is no more unassigned work left. This avoids that net rendering may hang due to unfinished work, because some intermediate result got lost. It may also reduce the render time when the local GPUs are out of work but Octane is still waiting for one or more render nodes to finish and return their result.
And read for rest: Standalone 2021.1.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-25)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-25)
WINDOWS DEMO BUILD (R15-25)
https://render.otoy.com/plugindownloads ... R2-win.rar
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
AaronWestwood
Thanks Aoktar, literally submitted a ticket yesterday about the "old volume behavior" missing in 2021, so this came at a perfect time!!! You're so speedy :)
I did have a quick question. Messing around with the filmic OCIO and it comes with a bunch of different contrast curves. Rendering to PV is 1:1 as in the LV which is great, but saving an image from the LV it doesnt have the looks there. I can copy to clipboard just fine and it looks the same, but the save render dialogue has the looks missing. See image attached, is this something which could be included in the File > Save Render dialogue?
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
Meet
Is octane voronoi noise added in the current build?
moebius
Is it just me, or does the "Add Render AOVs" not work?
AaronWestwood wrote:Thanks Aoktar, literally submitted a ticket yesterday about the "old volume behavior" missing in 2021, so this came at a perfect time!!! You're so speedy :)
It's different on UI. I think you didn't to try to change the options. See this
Meet wrote:Is octane voronoi noise added in the current build?
moebius wrote:Is it just me, or does the "Add Render AOVs" not work?
Both will be added/fixed on a next build.
AaronWestwood
The attachment a2.jpg is no longer available
Hey Aoktar
Im not sure im following. Ive clicked through and tried every single possible setting, the "Looks" just arnt there in the LV render dialogue option like your screenshot shows..
Im not talking about the colourspace, but the looks.
As mentioned, PV and Clipboard work 100% fine....just the LV render dialogue has this missing...
Kalua
Thank you, Aoktar for the quick upgrade!
Is there a quick way to convert existing octane lights into octane toon lights?
Regards,
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua wrote:Thank you, Aoktar for the quick upgrade!
Regards,
No, you can write a python script
Here's a short video to show new Notes node for node editor. Any feedback welcomes
https://www.youtube.com/watch?v=0hx6hN1i1iE
AaronWestwood
Hey Aoktar
Happy new year all! Just thought to re-query this to see if its do-able?
AW
