Hydra Solaris Documentation
Hydra Solaris
Ferdinand13
Hi there,
I've noticed that there is no dedicated documentation for Octane's Hydra Solaris plugin available in the support section. Given that the whole Solaris topic is quite complex, would it make sense to create one? Or maybe include a dedicated section inside the Houdini documentation? That'd be very helpful :)
Custom PC, Intel Core i7-6800K, 48GB RAM, 3x MSI GeForce RTX 2080 Super Seahawk EK, Windows 10
Razer Blade Pro 17, Intel Core i7-10875H, 32GB RAM, 1x NVIDIA GeForce RTX 3080, 1x EVGA GeForce GTX 1080 Ti Hybrid (eGPU), Windows 10
canderled
+1
BK
Ferdinand13 wrote:Hi there,
Thank you Ferdinand13 for your suggestions!
Include a dedicated section inside Houdini documentation sounds great!!
We would quickly run by our managers and update here!
cheers
Kind Regards
bk3d
Ferdinand13
Sounds great BK. Looking forward to it :)
Creative_Sheep
I would like to see Solaris Documentation; how do I use the custom AOV inside the Octane VOP, also how do I access all the preset custom AOV ?
BK
Hi Creative_Sheep,
Thank you for the post.
We plan to start our documentation as soon we are Octane feature complete.
Right now, Octane AOV output group(compositing AOV workflow) and Output (like OctaneROP) node are WIP.
Octane AOV product need to be added in Render settings>Standard>Ordered Products
Please find the sample file and let us know how it goes!
cheers
CustomAOV.zip
(89.46 KiB) Downloaded 484 times
Kind Regards
bk3d
Creative_Sheep
BK wrote:Hi Creative_Sheep,
cheers
I have the Octane_AOV node and the Rendersettings node connected to my USD tree, and the render passes work :D I wasn't aware one needed a render settings, then again there is no documentation :D
I don't know how to use the custom and global tabs in the OctaneAOV; also there are three lighting tabs in the OctaneAOV :D all listing the same options !
The show octane window in the render settings, is excellent; there must be benefits to opening Octane standalone and what can be done in Standalone and brought back into Solaris ?
Creative_Sheep
There is no information as how to use the Custom Tab and Global Tab ?
BK
Creative_Sheep wrote:There is no information as how to use the Custom Tab and Global Tab ?
Hi Creative_sheep
Sorry, after assigning/enabling the Custom AOV in the Octane Material, please go to the Custom tab and enable the custom AOV enabled in the Material.
Then run Octane IPR and select the rendered AOVs from the Viewing Output Icon.
It looks like the Global texture still has the bug assigning the texture. We would fix it in the future releases
cheers
Kind Regards
bk3d
Creative_Sheep
Hi Creative_sheep
cheers
I understand this, although when I enable Custom 1 in the Custom Tab of the Octane AOV, there is four options. Therefore if I have checked Custom 1 and Visible After Reflections; what is the name of this new AOV if I understand correctly ?
Return to “Hydra Solaris”
