Cinema4D version 2021.1-(R7) (Obsolete) 17.12.2021
iDani
Hi Ahmet,
you added a neat feature with objectcolors. Can you shortly explain how does it works?
" - Added the usage for Object Layer color or display color parameters as texture color in materials "
cheers Daniel
shine71 wrote:
aoktar wrote: For two questions, they are looks like CORE related. Did you check SA topic for changes? Maybe about GGX related revisions. We have a development phase with several builds during this period to show the revisions and gather the feedbacks.
viewtopic.php?f=24&t=78621
Can you provide some example scene for second problem(transmission thing)?
For last, are you talking about scenes are created with older versions?
Thanks for your reply, Ahmet!
I'll be checking again in SA topic if I find any clued about these differences in reflections, while I'm attaching here a sample scene with grass to see what I mean about transmission. I attach even a couple of screenshots, so will be more clear.
Regarding last question, yes, I was meaning what it happens opening scenes made with 2020. Texture color space not always is linear sRGB, and I double checked and changed where I saw that results were different than before...
Thanks again for your work!
Cheers
Hi Luca,
the Universal material is not setup correctly, in particular, the Transmission popup should be set to Diffuse, not Specular, since you are mimic a Diffuse + reflections material, not a Specular material:
Diffuse Transmission on the left, Specular Transmission on the right.
ciao,
Beppe
shine71
Thanks a lot, Ahmet and Beppe!
I'll be fixing all the amterials I did for greenery :)
Beppe, I'm really sad that you forgot my name, it's Marco :D
Un abbraccio e a presto!
I7 5930k - 32 Gb ram - 2 x RTX 2080ti
http://www.marcodattilo.com
iDani wrote:Hi Ahmet,
cheers Daniel
I hope this image explains it well
iDani
cheers Daniel
Thank you Ahmet, it works and it is great for colorizing Renderinstances. Fantastic! :-)
cheers Daniel
wangdanyang1120
There seems to be a problem with the shading normal AOV,I choose shading normal but he gives me diffuse.
And can't find shading normal in the Type.
Kalua
shine71 wrote:Hi everyone.
Thanks Ahmet for your work, as always.
I updated to 2021.1 R2 from 2020.1.5 and I've some question for you.
I noticed that reflections (mostly on metals) are less sharp and in some cases disappear.
Is there anything I should set?
Then, I set several materials for grass, leaves, etc. that have just a plane with an universal material taht has albedo and transmission (unfortunately it was the only way to have translucency and glossiness, avoiding to create a lot of mix materials and it worked fine with 2020. Now, with 2021, back side turn out white. ANy suggestion?
Lastly, in my saved material textures are in different color space, sometime in Linear sRGB+leagcy gamma, sometime in Non-color data and I've to check everytime, since it's a new feature. What I should do?
Sorry for several questions, but I'd like to switch to this version even for production, but I'd need to be sure about how much work I've to do for fixing these issues.
Thanks again and have a ncie evening.
For the colorspace issue: I already reported this somewhere here in the forum, some textures from files older than 2021.1 get set to "Non-color data" and causes wrong gamma display. My work around to quickly fix this is to use the "Octane Texture Manager", select all items and reset the Color space to "Linear sRGB + legacy gamma"
C4D 2025.1.1 Octane 2026.1 v1.8.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Octane User since V1 Beta
@Kalua, it's weird because when a new parameter added it uses a default value. And default value is constant. I cannot see this issue on tests with several old scenes. Could you please provide me some example scenes?
Kalua
aoktar wrote:@Kalua, it's weird because when a new parameter added it uses a default value. And default value is constant. I cannot see this issue on tests with several old scenes. Could you please provide me some example scenes?
I found an example. I will send you as private message.
shine71
Kalua wrote:For the colorspace issue: I already reported this somewhere here in the forum, some textures from files older than 2021.1 get set to "Non-color data" and causes wrong gamma display. My work around to quickly fix this is to use the "Octane Texture Manager", select all items and reset the Color space to "Linear sRGB + legacy gamma"
Thanks a lot for the tip, Kalua
Cheers
Return to “Releases”
