Cinema4D version 2021.1-(R7) (Obsolete) 17.12.2021
Hi all,
This is the newest stable plugin build based on first 2021.1 SDK. Any feedback will be much appreciated. Enjoy it!
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
For CORE improvements since 2020.2, please check the following Standalone link.
This is the matching Standalone: OctaneRender™ 2021.1.
2021.1-(R7) plugin revisions
- Critical fix for hairs which are not rendered in to Picture Viewer.
2021.1-(R6) plugin revisions
- Quick fix release for some problems on AOV manager and AOV node UI
2021.1-(R5) plugin revisions
- Improvements in Render Aov Manager. Added the saving/loading the presets.
- Added: Orbx export mode to render settings. It's an alternative way to export scene as ORBX and it maybe more accurate for some cases.
- Fix: Disable the hair control objects for rendering
- Fix: Revisions on render AOV group system
- Export dialog revisions
2021.1-(R4) plugin revisions
- Revisions on volume object's voxel shader sampling to it easier to work on
- Minor fix on aov items
- Added trial delay parameter to export dialog for solving the export issues
2021.1-(R3) plugin revisions
- Small revisions on render AOVs
- Custom icon styles: default/dark/brighter (from LV/GUI/Icon styles)
- Fixes on toon light parameters
2021.1-(R2) plugin revisions
- Missing lightID8 in renderpasses
- Fixed Vertexmap naming issues. It now guarantees to use any kind of names in VertexTags without any character problems or name collisions.
- Increased retry to avoid login collisions in commandline mode
- Conversion for old renderpasses in old scenes to new renderAOV system. Added a button under the Render AOVs section for that.
- Fix node select operation on node connections
- Some fixes and rearrangement on "Render AOVs" and "AOV groups" parts.
- Fix: render stall when any denoising passes selected without assigning some denoising GPU.
- Fix: Crashes with texture SOLO mode
- Fix for clipping material to let for using any kind of C4D texture projections
Changes of 2021.1 plugin
- Added ray_epsilon parameters in to Clipping material
- Fix: Leaked nodes and some problems with stacked materials in complex setups
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-25)
https://render.otoy.com/customerdownloa ... R7-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-25)
WINDOWS DEMO BUILD (R15-25)
https://render.otoy.com/plugindownloads ... R7-win.rar
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.015). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
eyeonestudio
Finally. Thank You. 2021 :o
eyeonestudio wrote:Finally. Thank You. 2021 :o
Yes finally, enjoy it!
eyeonestudio
Version name seems to be wrong. :)
And is the below function included?
-SDF from Mesh <--> Vectron connection
-Scatter - Poisson disk sampling (maybe don't need it in c4d!)
-User instance IDs and random texture for volume, SDF and Vectron instances (random textures working good)
>>is it possible to use instance-id? (volume-object does not support render-instance)
Well sorry, forgot to change it. Will fix it by a quick rebuild.
First is not included. For Second, it may work natively. But render-instances are not supported for volumes, also no need to implement it for vdb mode.
thanulee
Thanks so much for the hard and efficient work Ahmet. Latest versions have been rock stable!
Kalua
Thanks for the release, Aoktar!
I am gonna try it now!
Regards,
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
AaronWestwood
Congrats on the release! Few notes:
- The texture/scattering bug I mentioned in the previous thread still persists. The project I attached there should highlight this on both the 2020 and 2021 versions (ive attached it here again, it's set on a problematic frame but moving the camera will fix this).
- All daylight rigs are dialed WAY too warm (and red) in comparison to the 2020 versions and stay warm despite adjustments, the 2020 versions are accurate here but in 2021 we cant really use them like this. Find reference image and project attached. Project is just using the Octane default rig but the 3 other rigs also display this color mismatch (although you cant tint them, they are still too warm).
Looking forward to have these sorted before professional use :)
AW
SCATTER_CAMERA.zip
(46.79 MiB) Downloaded 437 times
SUN_VALUES.zip
(99.22 KiB) Downloaded 393 times
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
yazi10412727
EXR(octane) Incorrect output and No files
EXR Can output correctly
yazi10412727 wrote:EXR(octane) Incorrect output and No files
Probably doing something that's not supported. Better info would be great to explain what you do
