Yes it's requiring latest C4DBCres wrote:hazenkind,
May not be related...but have you tried updating to S24.111? Maybe the C4D v.24 program install is missing something on your system?
BC
Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Does anyone run into this situation?
After working with the Liveview window and closing it, C4D stops working and closes after showing an error message.
Not exclusive to the latest version but possibly since v2018 or so, happens in several C4D versions too.
Regards,
Regards,
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Could you please give some detailed information with proper data. So I can try to reproduce it! That's the way how we can solve the issues. Thanks!Kalua wrote:Thanks for the build, Aoktar! It works really well!
I am having issues, though, with the C4D take system: I don't think it is specifically related to the last Octane build: Sometimes changing one simple parameter from any element makes C4D crash - e.g. changing emissor's power.
I noticed having lots of takes make the file + Octane more unstable (over 10 crashes per day). Did anyone else notice related Take issues?
Regards,
Interesting, I already suspected this as well. Could be the explanation for some crashes here as well. I'm also having (well known) issues with the assets inspector when using the take system, but these are not related to Octane. Pity, as this is such a useful feature! C4D R21 here.Kalua wrote:Thanks for the build, Aoktar! It works really well!
Regards,
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
- thodosplay998
- Contact:
Hello Aoktar!
Light manager looks very promising!
I have few mechanical ideas:
- Instead of showing every object inside Include would be better to stick to a default C4D scheme when including any object every other octane tag gets that ID unchecked. By that I mean you already parsed object manager and know which object has Octane Obj Tag so no need to turn so there is no particular need to uncheck every Light ID by default. + would be great if you drop object inside Include/Exclude without any object tag it creates one.
- Exclude is the same + issue with showing anything(But I understand that it's a WIP).
Here is a quick Miro scheme for that.
https://miro.com/app/board/o9J_lx5ANUA=/
If needed I can add you as a team to Miro and we can discuss.
Win 10, RTX 2070 S
Https://cataclysm-vfx.com/
Https://instagram.com/thodos998
Octane SMC Plugin: https://gum.co/octmat
Hard to tell specifically when it happens,... I have been testing some things now: I have turned off "use texture cashing" and emptied the "texCache". Turns out C4D+Octane usability has improved a lot.aoktar wrote:Could you please give some detailed information with proper data. So I can try to reproduce it! That's the way how we can solve the issues. Thanks!Kalua wrote:Thanks for the build, Aoktar! It works really well!
Regards,
I let you know any news on these crashes.
Yeap... definetly something going on with Take systems and Octane (R21 and R23), both Octane 2021.5 R1 and R2. Scene with "Takes" crashes C4D systematically when I start rendering with Liveview window. After deleting all takes, scene began rendering again nicely.Kalua wrote:Hard to tell specifically when it happens,... I have been testing some things now: I have turned off "use texture cashing" and emptied the "texCache". Turns out C4D+Octane usability has improved a lot.aoktar wrote:Could you please give some detailed information with proper data. So I can try to reproduce it! That's the way how we can solve the issues. Thanks!Kalua wrote:Thanks for the build, Aoktar! It works really well!
Regards,
Hi Kalua, as said send me useful data to reproduce your steps. Bugreport+scene+video capture
I will write you back in private ASAP.aoktar wrote:Hi Kalua, as said send me useful data to reproduce your steps. Bugreport+scene+video capture
