Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
Hi all,
This is the latest stable build based on stable 2020.2.5 SDK. Any feedback will be much appreciated. Enjoy it!
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
For CORE improvements please check the following Standalone link.
This is the matching Standalone: OctaneRender™ 2020.2.5.
changes of 2020.2.5-R3 plugin
- R25 builds has been added
changes of 2020.2.5-R2 plugin
- Fix: accept the disabling effectors in scatter object and small update for drawing performance
- Fix: functionless "Include object node" parameter of DIRT node
- Fix: removed the Curvature node from list because that was wrongly added
- multi objects for C4D scatter pen
- Added silentmode activation for commandline.exe and -nogui parameters. It's mostly for avoiding the activation warning dialog with batch rendering
changes of 2020.2.5 plugin
- Fix: wrong direction for Octane lights when "use primitives=ON" with other shapes else of "sphere" and "rectangle"
- fix for "cycle" parameter with C4D gradient under OSL mode
Core fixes which may affects the plugins
  • Fixed issue causing some textures to be interpreted differently when using out-of-core.
  • Fixed SSS pass which was causing a difference between the main pass and the denoiser output passes.
  • Fixed issue with scenes with render layers and alpha channel enabled causing incorrect denoiser output.
  • Fixed universal camera diopter rotation to be interpreted as degrees instead of 0-1. (viewtopic.php?f=24&t=77888&p=402830#p402830)
  • Fixed broken rotation for 2D transforms.
  • Fixed an issue causing a freeze when disabling RTX while tone-mapping was happening.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-25)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-25)
OSX ENTERPRISE BUILD (R15-25)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-25)
DEMO WINDOWS: https://render.otoy.com/plugindownloads ... R2-win.rar
DEMO MACOS: https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
eyeonestudio
Thank You. Ahmet...
eyeonestudio wrote:Thank You. Ahmet...
You're welcome!
rezaansari
Thank You
2020.2.3-R6
2020.2.5
pc
5950x
128 ram
3090
win 10
thanulee
Thanks Ahmet for all the hard work.
I wanted to report a possible bug with PMC. Both in previous version and this one, it utilizes my gpus at 50-60%.
Probably core issue?
Cheers!
thanulee wrote:Thanks Ahmet for all the hard work.
Cheers!
I can't call it as a BUG, but it's not plugin related. Render calculation is handled by core
rezaansari wrote:Thank You
2020.2.3-R6
2020.2.5
pc
5950x
128 ram
3090
win 10
Can you invistigate it further and report back?
twik25
Hi Ahmet,
I'm running into a situation with the Inheritance tag using octane scatter. With the tag activated, as soon as I move my mouse over anywhere other than the LV, Octane goes into an instant refresh cycle. As soon as I turn off the tag, it doesn't do the refresh loop. I know this issue goes back to 2000.2.3 (I had that running but I installed this latest one and it was still an issue). Any ideas?
Tim
JCrugukhsG.mp4
(31.09 MiB) Downloaded 14470 times
Kalua
twik25 wrote:Hi Ahmet,
Tim
I also run into this sometimes with similar work conditions.
Other than this long time issue, this build looks great so far.
Regards,
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
anklove
Dirt include objects option doesnt work in this build
i7 10700k | Win 10 64 bit | RTX 3090
