I recently saw a rendering case made with Arnold on artstation.
After watching the tutorial, I know that was implemented using Arnold's volume displacement node.
I tried to reproduce this effect in 3dsmax with the octane renderer, using specular shader and volume node, but the displacement effect under the specular shader was somewhat unsatisfactory.
Later, I found that there is also a displacement under the volume node. But RGB textures have useless after connecting to this node.
After searching the tutorial, I know that I need to use osl textures, but the osl nodes of 3dsmax are not as many as in c4d, and I don't know where to find suitable osl textures.
Now I want to know whether this effect can be reproduced in the 3dsmax version of octane? I have been stuck at this step for 3 days.
please help me
How to render arnold like volume displacement with octane ?
- paride4331
Hi bakanopower,
displacement position option works like in Octane for C4D so you can use the OSL scripts stored in C4D in 3dsMax as well.
- text02.osl
- (169 Bytes) Downloaded 172 times
- vdb.zip
- (2.09 MiB) Downloaded 172 times
- bakanopower
Thanks for you repley.paride4331 wrote:Hi bakanopower,
May I ask what version of max you are using?Because when I open this file, my 3dsmax prompts me that the version is too low.
In addition, when I render VDB file, there will always be black shadows in it. Is it wrong where I set it up?
And can I convert the object to VDB in 3dsmax? Like in the first picture.
- paride4331
Hi bakanopower,
please try my updated sample, using Octane for 3dsMax 2020.2.5 11.11
3dsmax does not natively create .vdb, you need plugins like PhonixFD.
- vdb.zip
- (2.07 MiB) Downloaded 188 times
- bakanopower
Wow thanks for your answerparide4331 wrote:Hi bakanopower,
I can now use Tyflow to create a VDB format model and import it into the Octane volume~
However, I still have a question, that is, the UV of the object created by Octane Volume is determined based on the UV before it is converted to the VDB file? Or is there any other UV distribution method?
