Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
thanulee
Can we fix the $prj token please? It doesnt work anymore in r23 neither in s24 and in 2020.2.4 and on this version.
erbe
Bug with Vertex Map as Alpha in Composite Material. The vertex maps do not work in a composite material. With the older version 2020.2.1-R3 with the same settings is no problem.
I use Cinema 4d R23
erbe wrote:Bug with Vertex Map as Alpha in Composite Material. The vertex maps do not work in a composite material. With the older version 2020.2.1-R3 with the same settings is no problem.
I use Cinema 4d R23
What happens with 2020.2.4?
erbe
There is the same problem. :?
erbe wrote:There is the same problem. :?
Please send me a sample scene and enough info to describe the issue.
erbe
I send you a small example from the problem. It is Blend material with a vertex map as alpha.
Vertex Test.zip
(119.4 KiB) Downloaded 293 times
erbe
Does anyone have any ideas about the problem?
erbe wrote:Does anyone have any ideas about the problem?
Connect it to mask2 and rename to "Vertex map" from "Vertex-Map". You can see mask1 is doing nothing if you use with any different texture. Also Vertex Map's are name sensitive since last builds and doesn't accept exceptional characters.
drigogers
Just checking if this version accept multiple graphic cards?
I'm running 4 1080
tks
drigogers wrote:Just checking if this version accept multiple graphic cards?
I'm running 4 1080
tks
Yes, but as always, you need the Enterprise version, Studio versions are limited to max 2x GPUs.
ciao,
Beppe
Return to “Releases”
