Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
Hi all,
This is the latest stable build based on stable 2020.2.3 SDK. Any feedback will be much appreciated. Enjoy it!
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
For CORE improvements please check the following Standalone link.
This is the matching Standalone: OctaneRender™ 2020.2.3.
Plugin changes for 2020.2.3-R7
-Fix: Correct outputs with OCIO/sRGB and 32/16/8 bit buffers
-Fix: Small fixes for OCIO interface
-Fix: Crash and iteration improvements with xpTrail and color data
-Fix: LV display glitch on start and mode changes
Plugin changes for 2020.2.3-R6
Fix: C4D's Bitmap loading issues
Fix: Preview issues with node editor
Fix: Bring back the OCIO select button with 8-bit buffer
Plugin changes for 2020.2.3-R5
- Bring back OCIO for 8-bit buffer type. It's for fixing the issues of saving sRGB PNGs
Plugin changes for 2020.2.3-R4
- Better emulation of Cinema4D's PBR materials in rendering session. Better diffuse/opacity/reflection/SSS emulations
- Small behavior change for arealight without Octane light tag.
- Revisions on Settings window
- Fix: Node editor button in Layered Materials, picking unvisible GUI on node boxes
- Fix: update issue on cloned elements by multi-instance
- Fix: Unconnected nodes in tag of volume spotlight
- Picking feature in LV for hair objects and materials
- Vertex Map tag fixes, you can now use it a string attribute if you rename it. Even with attribute texture in this case.
- Now you can use the "Force tone mapping" option for other color spaces, not just with OCIO anymore.
- Use denoised beauty is back for sRGB buffer type
- Other fixes
Plugin changes for 2020.2.3-R2
- Fix: Avoided to restart the render with click on render region mode
- Quick S24 build, extended support is on the way
- Some minor fixes
- Fixing a deadlock crash case for node connections
- Fix: "Settings/Devices/Use RTX" checkbox
- Fix: Solo mode for specular/metal
- Fix: Selection problem on pasted nodes
- Fix: render stuck with nothing selected for colorspace in OCIO
- First quick support for DEM_EARTH_CLONER object type
Core fixes which may affects the plugins
- Fixed crash in the surface scatter node when you try to use the area based distribution on a mesh that doesn't have polygons.
- Fixed portal material being non-transparent to shadow rays.
- Fixed clamping of HDR input values in the color correction texture.
- Fixed missing updates when a transform node other than the transform value node is changed.
- Fixed CUDA failure when rendering toon materials.
- Fixed incorrect rendering of toon materials with opacity < 1.
- Fixed CUDA failure when vertices of a mesh are moved around in quick succession and RTX is enabled.
- Fixed broken auto bump of vertex displacement if dirt is used in the material as well.
- Fixed missing render update if a toon ramp is modified.
- Fixed superfluous geometry updates when an input of a volume node got changed.
- Fixed specular transmission "leaking" into the indirect reflection render pass.
- Fixed crash when you authenticate more than once in a session.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-24)
https://render.otoy.com/customerdownloa ... R7-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-24)
OSX ENTERPRISE BUILD (R15-24)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-24)
DEMO WINDOWS: https://render.otoy.com/plugindownloads ... R6-win.rar
DEMO MACOS: https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
thanulee
Thank you Ahmet!
thanulee wrote:Thank you Ahmet!
My pleasure, enjoy it!
Kalua
Thank you, Aoktar!
Really appreciate it!
Regards,
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Gregor.Zimmermann
Thanks Ahmet!
cannon126
Thanks for the update.
I found a bug pretty quickly that could just be unique to my machine:
Every time I try to use the search-bar in the node editor, I get a spinning wheel and need to end c4d from the task manager. I can get around this by 'tab' searching.
R23
Windows 10
Studio Driver 461.92
Ryzen 5950x - 2X RTX 3090 - 128GB RAM
Windows 11
cannon126 wrote:Thanks for the update.
R23
Windows 10
Yes, checked that. It's an ID shifting related crash, will be fixed on next build. Or I can make a quick replacement if it's critical for you. You can work-around with new search window
Viki.SK
Its not relevant but is there any plan to make a Simplified UI like Redshift's recent testing?
This=> https://www.redshift3d.com/forums/viewthread/36701/
cannon126
R23
Windows 10
Glad it's not just me. Certainly not critical, I imagine you have more pressing things to work on. I'm just getting in the habit of TAB searching now. :)
Windows 11
Viki.SK wrote:Its not relevant but is there any plan to make a Simplified UI like Redshift's recent testing?
Our system is far simpler for my opinions. I cannot see that, what kind of simplification that's better?
