Octane 2020.2.3 for Unreal Engine - v0.44: Unreal 5
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine 0.44
Changes:
  • Added Unreal 5 support
    *note: nanite meshes are currently loaded as LOD 0, which can consume a lot of CPU and GPU memory when they are highly detailed
  • UE5: Moved the octane dropdown menu in the UE4 toolbar to the octane top menu.
  • UE5: Moved the big octane button in the UE4 toolbar to the octane top menu. It is now: "load octane"
Fixes:
  • Materials: Component masks on floats now work
  • Materials: Rare texture sample bug has been fixed
  • Materials: Fixed bugs where alpha of a texture was ignored
  • Textures: Fixed rare bug where alpha of a texture was not copied
  • Fixed hard crash when using virtual textures
  • Fixed hard crash that could occur when using engine textures
  • Fixed rare hard crash that could randomly occur during material conversion
UE 5.0EA
Studio Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
UE 4.26
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
Kalua
Thanks, team!
I can´t seem to download Enterprise Installer: https://www.otoyserver.com/unrealengine ... E5.0EA.exe
It takes me to:
Not Found
The requested URL /unrealengine ... E5.0EA.exe was not found on this server.
Apache/2.2.34 (Amazon) Server at www.otoyserver.com Port 443
Regards,
C4D 2025.3.3 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
azen
Kalua wrote:Thanks, team!
It takes me to:
Not Found
Apache/2.2.34 (Amazon) Server at http://www.otoyserver.com Port 443
Regards,
Hello Kalua,
Thank you for letting us know, and apologies for the inconvenience. We will get those links up and running again as soon as possible.
Cheers,
Azen
ChrisHekman
It takes me to:
Not Found
Regards,
Links have been fixed
FL4NKey
Hi, I tried v44 on both 4.26 and 5EA.
In this version it finally doesnt crash when using UDIMs/Virtual textures, but for some reason Octanes sees all the UDIMs wrong and scatters them all around the objects incorrectly. Any idea why? They are correct in normal viewport.
EDIT: Specifically, from additional testing on simple cube, it seems it actually applies only last top right tile #06 to the entire cube, instead starting from bottom left 01 and going up to 06 for each side.
ChrisHekman
FL4NKey wrote:Hi, I tried v44 on both 4.26 and 5EA.
UDIM is not supported atm, which I suspect causes UVs and UDIM textures to not match. Ill see if i can add that functionality.
webrob123
ChrisHekman wrote: UDIM is not supported atm, which I suspect causes UVs and UDIM textures to not match. Ill see if i can add that functionality.
Would love to see UDIM support too. Keep up the good work Chris!
Return to “Releases”
