Flickering render with motion blur on mixed GPUs
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Powel2097
I am having issues with a render in 2 different scenes.
System:
Win10 64Bit
3x 2080ti
1x 3080ti
Cinema 4D R21 with OctaneRender-for-C4D-2020.2.4-R2 (R1 same issue)
When rendering a scene with all 4 GPUs, I get flickering on the surfaces.
I tried adjusting ray epsilon, denoiser.
I am using pathtracing.
When rendering with only 3x 2080ti I get a good render.
When rendering with only the 3080 I get a render that is a bit darker on the bright spots.
It appears that it switches between the two card types.
When disabling Motion blur, the effect is gone. Even when the camera is very slowly moving.
here is the difference between these two card types.
Its the same material, I masked out in AE to see the difference.
Also attached is a quick render with the flickering using all 4 cards.
Look at the pot.
Right now I cant render any scene with motion Blur using all cards together.
Flicker with motionBlur.mp4
(209.28 KiB) Downloaded 869 times
since this is not a plugin issue, but a core issue, please, export the scene to Standalone, then share the .orbx file in this discussion with the core team, even with a Private Message:
viewtopic.php?f=24&t=77888
ciao Beppe
Return to “Bug Reports”
