Hello
I have had a problem for some time
if I calculate the AO pass in the viewer
everything is fine, but when I save it in PNG format, the image is all damaged
same as TGA or other format with transparency, no problem in jpeg
problemeAO
- paride4331
Hi pierres,
I can't reproduce your issue, saving .png it seems ok.
Could you share your issued file please?
- paride4331
Hi pierres,pierres wrote:The saved file is paluao.png
I don't know if it comes from octane, not at all for that matter.
I can send the .max if needed
yes please, it could help to figure out.
- paride4331
Hi pierres,pierres wrote:Hello
.max in attachment
thank you so much
you need to zip it.
regards
sorry
- La Palue GOCTANE.zip
- (427.1 KiB) Downloaded 139 times
- paride4331
