problemeAO
pierres
Hello
I have had a problem for some time
if I calculate the AO pass in the viewer
everything is fine, but when I save it in PNG format, the image is all damaged
same as TGA or other format with transparency, no problem in jpeg
pb in save
pb in save
no pb in viewer
no pb in viewer
paride4331
Hi pierres,
I can't reproduce your issue, saving .png it seems ok.
Could you share your issued file please?
pierres
I don't know if it comes from octane, not at all for that matter.
I can send the .max if needed
paride4331
pierres wrote:The saved file is paluao.png
Hi pierres,
yes please, it could help to figure out.
pierres
Hello
.max in attachment
thank you so much
paride4331
pierres wrote:Hello
.max in attachment
thank you so much
Hi pierres,
you need to zip it.
regards
pierres
sorry
La Palue GOCTANE.zip
(427.1 KiB) Downloaded 125 times
paride4331
Hi pierres,
please set Vieport tone mapping to HDR.
pierres
Hooo !! thanks Paride
Return to “Autodesk 3Ds Max”
