Rendering artifacts
lamerehic
I am rendering a 100m square displaced plane with a universal node and a pbr texture.
I a metting triangle artifacts on rendering.
Cant find from what it comes from.
Any clues?
lamerehic
I tried to change the ray epsilon value up or down, but i cannot get rid of the littles triangles... In lower values i get more and bigger ones.. but in Higher values, it does not change a thing, Seems that i cannot have a better result than what i got...
juanjgon
Try to use the vertex displacement node to check if it helps.
lamerehic
When i unplug the normal map everything looks ok, so i think the normalmap is the problem. but in LW native it works fine.. :shock:
juanjgon
Hmm, I'm not sure if the displacement and normal maps can work at the same time, or if in fact this makes sense.
lamerehic
In fact, i created a displaced plane and saved transform the object.
I only got a bump and a normal map
cf screenshot
lamerehic
And here the render target
dmodric
Try not to use normal and bump maps at the same time. I have noticed some artifacts when using both.
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
Lewis
Where is Displacement in that screengrab? I don't see it connected ? Only Bump and Normal ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
lamerehic
Lewis wrote:Where is Displacement in that screengrab? I don't see it connected ? Only Bump and Normal ?
As i said, i did a "save transformed object" in order to have/see the real geometry in orthographics views
dmodric wrote:Try not to use normal and bump maps at the same time. I have noticed some artifacts when using both.
Thanks for the tip, i Will try to remove one of the both normal/bump map and see if it's ok .
Return to “Lightwave 3D”
