Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
- 14bmwc780nike
- Contact:
aoktar wrote:Would mind to do a better feedback? Area lights without Light tag will have a different intensity. It's not absolutely adviced to use without tags, because of don't having explicit control for light parameters.14bmwc780nike wrote:Under R21 (updated to latest with current nVidia studio drivers) all lights built in an existing studio seem to have lost their intensity. Had to revert back to R3.
Scene does use Octane light tags. I can't share the scene publicly.
Update - checked R5 and still having the same issues. I did DM a link to my icloud drive to the file. If I remove the images from the Octane light tags, the scene lights do work but of course not in the desired fashion.
R4 Render R3 Render
H: C4D 2025 | Asus ProArt X870E-CREATOR | Win 11 64bit Pro | AMD R9 7950X3D 4.2z 16-Core | 96GB | 3070ti/3090
W: C4D 2025 | Asus WRX80E-SAGE| Win 11 64bit Pro| AMD TRPRO 5965WX 24-Core | 128GB | 3090Ti
Cheers,
Marcus | 3dconge.com | @RockingThePIxel
Cheers,
If you convert Bitmaps in light tags to ImageTexture, that will be fix it. I'm looking for what changed and how to fix it14bmwc780nike wrote:aoktar wrote:Would mind to do a better feedback? Area lights without Light tag will have a different intensity. It's not absolutely adviced to use without tags, because of don't having explicit control for light parameters.14bmwc780nike wrote:Under R21 (updated to latest with current nVidia studio drivers) all lights built in an existing studio seem to have lost their intensity. Had to revert back to R3.
R4 Render R3 Render
Released a hotfix build for some issues. Links are on first page, download links will be updated soon.
Thanks for the R6 update. Cant save file if there is no folder. Is that a bug?
- Cinema_4D_2021-05-22_17-32-22.png (11.15 KiB) Viewed 4779 times
- wrapthereal66
Thanks for the update! 2 things that i found :
1/ octane crash with a background object from c4D
2 / solo node is working just when you add a transform node to it!
I get this freeze in viewport when i try to move a cloner with splines. Object tag>render as hair
It seems to recalculate everything even with a viewport pan. Is there a way to fix/optimize this behavior?
See issue here: https://www.dropbox.com/s/wcsg7xwscd9yq ... .webm?dl=0
Same here with XParticle and xpTrail and render as hair.thanulee wrote:Hi,
Same here too. Freezes with render as hair in xp trailhazenkind wrote:Same here with XParticle and xpTrail and render as hair.thanulee wrote:Hi,
- 14bmwc780nike
- Contact:
Thank you for the update!aoktar wrote:If you convert Bitmaps in light tags to ImageTexture, that will be fix it. I'm looking for what changed and how to fix it
Cheers,
Cheers,
