Bitmap Random Tiling OSL
RTF
Recently,I find 3dmax 2021.2 update a osl named 'Bitmap random tiling' which can solve texture repetition.
And I extracted the OSL from 3DMAX,but can't compilation and show something wrong.
I don't know much about OSL.Can anyone compile the OSL to work with OCTANE?
This is the Bitmap random tiling effect.
https://www.stateofartacademy.com/3ds-m ... -osl-maps/
This is the code
// Lookup a bitmap and make random variations so no tiling is evident
// RandomTilingBitmap.osl, by Zap Andersson
// Modified: 2020-06-23
// Copyright 2020 Autodesk Inc, All rights reserved. This file is licensed under Apache 2.0 license
//    https://github.com/ADN-DevTech/3dsMax-OSL-Shaders/blob/master/LICENSE.txt
shader RandomTilingBitmap
[[ string help  =
    "<h3>Bitmap Random Tiling</h3>"
	"Look up a bitmap from passed in UV coordinates and modify each "
	"repetition of the bitmap such that tiling is not evident. Has "
	"a mode to properly transform normal maps. Outputs the "
	"modified UV so it can be hooked up to other Bitmap Lookup shaders "
	"to apply the identical randomness, plus outputs the Random Index "
	"itself to drive downstream modifications that are in sync with it.",
   string label = "Bitmap Random Tiling",
   string version = "1.0" ]]
  point  Pos   = point(u,v,0)
  	[[  string label= "UV Coordinate",
  		string help = "The 2D coordinate at which the texture is looked up." ]],
  float  Scale  = 0.25
  	[[  string help = "A linear scale factor. For more complex UV manipulation, connect the UVWTransform." ]],
  string Filename = "uv-grid.png"
  	[[ string widget="filename",
  	   string label="File name",
  	   string help="The name of the texture to look up" ]],
  int   NormalMap = 0
  	[[ string widget="checkBox",
  	   string packName = "Normal Map",
  	   string label    = "Normal Map",
  	   int    connectable = 0,
  	   string help="If the texture is a normal map, special transformations have to be applied to retain the proper orientation upon rotation. Check this box if the texture is a normal map." ]],
  int   NormalFlipR = 0
  	// Metadata changed by Save to Previous
		string label    = "Flip Red",
		int connectable =  1,
  	    string help="Invert red component for rotation of normal maps." ]],
  int   NormalFlipG = 0
		string label    = "Flip Green",
	  	string help="Invert green component for rotation of normal maps." ]],
  string Filename_UDIMList = ""
  	[[ string label="Viewport UDIM List",
  	   string help="The list of UDIM items to load into the viewport. If empty, will be deduced from the file system automatically. " ]],
  string LoadUDIM = "Load UDIM..."
  	[[ string widget="max:actionButton",
  	   string actionID="loadUDIM(\"Filename\")",
  	   string help="Select a set of files to load as an UDIM.",
  	   int    connectable = 0 ]],
  int    UDIM   = 0
		[[ string widget="checkBox", string label="UDIM-compatible lookup",
  	   string help  ="Modifies the UV coordinate so that UDIM's are looked up similar to the max MultiTile map" ]],
  string WrapMode = "periodic"
  	[[ string widget="popup", string options = "default|black|clamp|periodic|mirror",
  	   string label="Wrap Mode",
  	   string help="How the texture wraps: (black, clamp, periodic or mirror)." ]],
  int   Randomize    = 1
		[[ string help =
    	  "Enables all randomization. Can be disabled for debugging purposes. ",
    	  int connectable= 1 ]],
  int   RandomizePos    = 1
		[[ string help =
    	  "Enables randomization in UV space by making a 'distorted grid' and  "
    	  "apply one variation in each 'square' of the grid. "
    	  "If this is OFF, no spatially varying randomness occurs. "
    	  "There is still variation per Seed value. If Seed is driven from "
    	  "e.g. a Node Handle map, this gives one random value per object.",
  float RandScale    = 1.0
    [[ string help =
    	  "Scale of the 'distorted grid' in relation to UV space. "
    	  "A value of 1.0 means the 'distorted grid' is the same size as a "
    	  "unit square in UV space, a smaller number makes the grid smaller and "
    	  "a larger value makes it larger. "
    	  "A value of zero disables spatially varying randomness "
    	  "but still makes a variation per Seed value. If Seed is driven from "
    	  "e.g. a Node Handle map, this gives one random value per object." ]],
  float WiggleScale  = 0.2  [[ string help="Scale of the 'wiggliness' of edges, in relation to the UV space" ]],
  float WiggleAmount = 0.25
  	[[ float min=0.0, float max=10.0,
  	   string help="Amount of 'wiggliness' on the edge of the randomness grid, to obscure the fact that it is a grid."
  float EdgeFuzz     = 0.1
  	   string help="Amount of 'crossfade' at the edge of the randomness grid. Note this is computed stochastically and may introduce some noisiness. "
  float RotMin = 0.0     [[ float min=-360.0, float max=360.0 ]],
  float RotMax   = 360.0 [[ float min=-360.0, float max=360.0 ]],
  float ScaleMin = 1.0   [[ float min= 0.1, float max=10.0 ]],
  float ScaleMax = 1.0   [[ float min= 0.1, float max=10.0 ]],
  float UOffset = 0.0,
  float VOffset = 0.0,
  int   Seed = 0 [[ string help = "Random seed. Connect to e.g. Node Handle map to have per-object randomness" ]],
  vector HSVMin   = vector(0.0,1.0,1.0),
  vector HSVMax   = vector(0.0,1.0,1.0),
  int    AutoGamma   = 1
		[[ string widget="checkBox", int connectable= 1 ]],
  float  ManualGamma = 1.0
  	[[ string label="Manual Gamma" ]],
  output color Col = 0     [[ string label="Col (RGB)" ]],
  output float R = 0,
  output float G = 0,
  output float B = 0,
  output float A = 1,
  output float Luminance = 0,
  output float Average = 0,
  output point UV = 0,
  output int   RandomIndex = 0,
	// Skip empty files
	if (Filename == "")
		return;
	point p = Pos  / Scale;
	point noisepoint = 0;
	if (RandomizePos)
		point wigglepoint = p / WiggleScale;
		noisepoint = p / RandScale + (noise(wigglepoint, Seed)-point(0.5,0.5,0.0)) * WiggleAmount + noise("hash", p) * EdgeFuzz;
	point rotscale  = Randomize?noise("cell", noisepoint, Seed + 10):0;
	point position  = Randomize?noise("cell", noisepoint, Seed + 11) - point(0.5,0.5,0.0):0;
	point hsvchange = Randomize?noise("cell", noisepoint, Seed + 12):0;
	// Output one of the randomizers so people can do external randomization
	// based on these
	RandomIndex = int(rotscale[2] * 500000000);
	// Compute the actual rotation (in radians)
	float rotation = radians(mix(RotMin, RotMax, rotscale[0]));
	vector hsvTweak = mix(HSVMin, HSVMax, hsvchange);
	p -= point(0.5,0.5,0.0);
	p  = rotate(p, rotation, 0.0, vector(0.0,0.0,1.0));
	p /= mix(ScaleMin, ScaleMax, rotscale[1]);
	p += point(position[0] * UOffset, position[1] * VOffset, 0.0);
	p += point(0.5,0.5,0.0);
	UV = p;
	// Default lookup, just use u and inverted v...
	float ulookup = p[0];
	float vlookup = 1.0 - p[1];
	// But for UDIM compatibility and max's idea that 0,0 is in
	// lower left corner, we need this juggling of v....
	if (UDIM)
		float vfloor  = floor(p[1]);
		float vfrac   = p[1] - vfloor;
		vlookup = vfloor + (1.0 - vfrac);
	Col  = texture(Filename, ulookup, vlookup, "wrap", WrapMode, "alpha", A);
	if (NormalMap  == 0)
		color hsv = transformc("rgb", "hsv", Col);
		hsv[0] += hsvTweak[0]; // Offset the hue
		//hsv[1] *= hsvTweak[1]; // Scale the saturation
		hsv[2] *= hsvTweak[2]; // Scale the value
		Col = transformc("hsv", "rgb", hsv);
		// Simulate saturation via gamma - more visually pleasing
		Col = pow(Col, hsvTweak[1]);
	else
		// Flip components if needed
		if (NormalFlipR) Col[0] = 1.0 - Col[0];
		if (NormalFlipG) Col[1] = 1.0 - Col[1];
		Col = rotate(Col, rotation, point(0.5,0.5,0.0), point(0.5,0.5,1.0));
		// Flip components back if needed
	int channels;
	gettextureinfo(Filename, "channels", channels);
	if (channels < 4) // No alpha? Set it to opaque
		A = 1.0;
		if (WrapMode == "black") // 2018-04-25: Allow Decals
			if (p[0] < 0.0 || p[0] > 1.0 ||
			    p[1] < 0.0 || p[1] > 1.0)
			    A = 0.0;
	if (!NormalMap)
		// Temporary workaround for color space issues
		if (AutoGamma)
			if (!endswith(Filename, ".exr") &&
				!endswith(Filename, ".EXR") &&
				!endswith(Filename, ".hdr") &&
				!endswith(Filename, ".HDR") &&
				!endswith(Filename, ".tx")  &&
				!endswith(Filename, ".TX"))
				// Gamma 2.2 for sRGB approx)
				Col = pow(Col, 2.2);
		else
			if (ManualGamma != 1.0)
				Col = pow(Col, ManualGamma);
	R = Col[0];
	G = Col[1];
	B = Col[2];
	Luminance = luminance(Col);
	Average   = (R + G + B) / 3.0;
:shock: :shock: :shock:
(8.7 KiB) Downloaded 301 times
you cannot have multiple output pins with Octane OSL nodes, but... do you know that Octane 2020.2 has a new native Chaos node for this?
ciao Beppe
RTF
Thanks,I'll try the Chaos node. :D :D :D
ceen
It does not work wih displacement.
RTX 5090, Maxon One
probably you are using the Displacement node in Texture mode, that does not allow any texture transformation.
You need to switch to Vertex Displacement, to make it works:
Happy GPU rendering,
ciao Beppe
ceen
bepeg4d wrote:Hi,
ciao Beppe
Thank you!
RTX 5090, Maxon One
