ACES ocio setting
paride4331
I hope it helps.
samsue
According to the ACES academy website, you should use aces_CG for renderings. Have you tested it?
paride4331
samsue wrote:According to the ACES academy website, you should use aces_CG for renderings. Have you tested it?
Hi samsue,
Play the right way, according to your needs.
samsue
Not about what is right for me, I recommend you to read this website from Chris Brejo;
https://chrisbrejon.com/cg-cinematograp ... stem-aces/
paride4331
Hi samsue,
"Karu wrote:
Octane is a spectral renderer and doesn't render internally in any RGB color space (i.e. there is no working space). It can be considered to output directly in the color space chosen, be that ACEScg, ACES2065-1 or any other space available.
viewtopic.php?f=85&t=76633&p=394855&hilit=+aces#p394855
samsue
This is the kind of information we need, to make things clear.
Now it makes sense! Thanks
samsue
Are the textures converted automatically?
paride4331
samsue
I know how to load textures -.-"
But in the case of ACES, as in the ACES documentation and several articles on the subject says , in most engines you would have to specify the texture input like Utility-linear etc...
paride4331
Return to “Autodesk 3Ds Max”
