Hello,
I'm facing the same issue on windows pc. The configuration of my pc is here-
Graphics Card - RTX 3070 8GB
NVIDIA CUDA® Cores 5888
Boost Clock (GHz) 1.73
Base Clock (GHz) 1.50
RAM - 32GB
Processor - Core i9-9900K 3.60GHz
I'm using octane 3.07. Please help me out.
no CUDA device supported by Octane Render - Help!
I'm having the same issue - just purchased Octane 2020 Enterprise and built a new rig. Im trying to install Octane 2020.1.5-R4 Have the EVGA RTX 3090 FTW3 Ultra
I'm on windows
I'm on windows
Fixed it - installed the latest CUDA package and it worked - also went into octane settings and selected the GPU. Thx
to work with the latest versions of Octane, you need to firstly update the Nvidia driver to version 456.38 or greater, with a clean installation.
Then install also Standalone, to be able to install the latest cuDNN library:
viewtopic.php?f=33&t=76603
During the first start, you will be asked to press the download button, to automatically install the necessary cuDNN library:
If not enough, please go to Octane Settings/Devices panel, and check that the Nvidia GPUs are enabled.
ciao Beppe
ciao Beppe
- dartestudio
he seguido los pasos de las respuestas de este foro para solucionar el problema y sigue igual, he descargado el GPU-Z y el octanerbench.4, sin resultado.
tarjeta grafica NVidia quadro P.2000, windows 10 , plugin octaner render C4D.R20. licencia de alquiler. me pueden ayudar?
- dartestudio
Started logging on 12.04.21 18:19:01
OctaneRender Demo 2020.1 (8010000)
device 0: failed to find a CUDA binary matching compute model 8.6
I can't make it work in max 2021 have latest studio drivers rtx 3090 , standalone works fine - it is a demo for both on win10 enterprise
- paride4331
Hi Keks,keks wrote:Started logging on 12.04.21 18:19:01
Octane for 3dsMax plugin v2020.2.3 demo version (working with RTX 3090) will be updated as soon as possible.
