no CUDA device supported by Octane Render - Help!
eshtiaque1234
Hello,
I'm facing the same issue on windows pc. The configuration of my pc is here-
Graphics Card - RTX 3070 8GB
NVIDIA CUDA® Cores 5888
Boost Clock (GHz) 1.73
Base Clock (GHz) 1.50
RAM - 32GB
Processor - Core i9-9900K 3.60GHz
I'm using octane 3.07. Please help me out.
hoice
I'm having the same issue - just purchased Octane 2020 Enterprise and built a new rig. Im trying to install Octane 2020.1.5-R4 Have the EVGA RTX 3090 FTW3 Ultra
I'm on windows
hoice
Fixed it - installed the latest CUDA package and it worked - also went into octane settings and selected the GPU. Thx
meikonishi
Same error////
to work with the latest versions of Octane, you need to firstly update the Nvidia driver to version 456.38 or greater, with a clean installation.
Then install also Standalone, to be able to install the latest cuDNN library:
viewtopic.php?f=33&t=76603
During the first start, you will be asked to press the download button, to automatically install the necessary cuDNN library:
If not enough, please go to Octane Settings/Devices panel, and check that the Nvidia GPUs are enabled.
ciao Beppe
dartestudio
he seguido los pasos de las respuestas de este foro para solucionar el problema y sigue igual, he descargado el GPU-Z y el octanerbench.4, sin resultado.
tarjeta grafica NVidia quadro P.2000, windows 10 , plugin octaner render C4D.R20. licencia de alquiler. me pueden ayudar?
dartestudio
keks
Started logging on 12.04.21 18:19:01
OctaneRender Demo 2020.1 (8010000)
device 0: failed to find a CUDA binary matching compute model 8.6
I can't make it work in max 2021 have latest studio drivers rtx 3090 , standalone works fine - it is a demo for both on win10 enterprise
paride4331
keks wrote:Started logging on 12.04.21 18:19:01
Hi Keks,
Octane for 3dsMax plugin v2020.2.3 demo version (working with RTX 3090) will be updated as soon as possible.
keks
oh ok I was going mad figuring out why it does not work. will there be and update soon ? evaluating for a purchase
