Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
pxlntwrk
VVG wrote:Where to get information on new nodes?
How to work with them?
- New texture nodes: composite..
Here is a video showing how to create a "Lightmixer" type setup with the new AOV system.
Light mix with AOV system - Octane Render and Cinema 4d
Cheers!
pxlntwrk.net
gergo_szabo22
hey,
does network render work with this version?
im getting an "invalid version (8.01.5 [0])" error at the node list in the network preferences menu.
thanks!
VVG
Cheers!
thanx!
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
wrapthereal66
run so smoothly ! i don't have any probleme by far with my 2X 3090 ! Zero crash ! :D thanks you !!
VVG
aoktar wrote: I don't have any manual yet. Not complicated to solve that for my opinion. There will be update on manual when stable version out. This is a preview version. Please read first post why I release it.
rayswitch = raytype osl viewtopic.php?f=21&t=71597 and viewtopic.php?f=87&t=67849
chaos node - very slow, i know this is a kernel problem
useruser
hi ahmet,
during setting up a project i find a strange behavoir with refractions:
rendered with oc 2020.1.5_R4
and rendered with
2020.2-RC5 (Preview release)
is that a known issue?
if you want i send you the projectfiles via PM
beside that: during the last 3 days oc2020.2-RC5 (Preview release) works very stable!
great job (as usual) ahmet! thanks a lot for the new version!
cheers
oli
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Kalua
useruser wrote:hi ahmet,
and rendered with
cheers
oli
There seems to be some intersecting speculars there. Have you tried to disable the new <<nested dieletrics>> feature? Or pherheps play with material priorities?
Octane User since V1 Beta
useruser
hi kalua,
disabling "nested dielectics" works!
i doublechecked the geometry: no intersectictions or some other nasty stuff. i also played
with ray-epilon-value: no effect.i have to disable "nested dielectics" to get rid of this render-failure.
thanks! :)
Kalua
useruser wrote:hi kalua,
thanks! :)
It is no render-failure: You must set priorities values to those materials, because you seem to have a specular shader intersecting another body with different shader. You will find the priority value in shader's common tab.
Cheers,
VitaliyHavrylyuk
Is there any information on how to get the "old" tonemapped feature?
For example, right now I'm trying to render a z-depth pass with a VDB, in the old system when I changed the tonemap type to Tonemapped the VDBs would become visible in the zdepth pass. I can't seem to find a similar option in this pre-release.
Thanks! :D
Return to “Releases”
