Live Viewer vs Picture Viewer
BakerImageGroup
I've checked everything I could fine but I can't get my live viewer to match output in Picture Viewer.
Any ideas?
2019.1.5
lanklaf
Any ideas?
2019.1.5
Change the Render buffer type from Float (linear) to Float (tonemapped).
Float (linear) does not store any camera settings.
System:
i7 8700K / RTX 2020 / 16GB RAM
madmandrax_1
I have the same problem. Render Buffer Type is set to Float (tonemapped), the liveviewer setting is set to HDR tonemapped. Any ideas?
Picture Viewer
Picture Viewer
Live Viewer
Live Viewer
madmandrax_1 wrote:I have the same problem. Render Buffer Type is set to Float (tonemapped), the liveviewer setting is set to HDR tonemapped. Any ideas?
Put your scene without any content, just current camera and keep render settings. Then I'll say what's wrong
madmandrax_1
Thanks, find the project file attached.
empty.zip
empty project
(210.75 KiB) Downloaded 164 times
Hi madmandrax_1,
you have not shared the HDRI, so the light cannot be the same, anyway, please avoid to mix OctaneRender settings with other render engines settings:
And set the Geometry Engine to “All objects movable”:
Looking forward for your feedback,
ciao Beppe
Deprecated options are meaning they will be removed sometime later.
Also, disable "use denoised beauty pass" for trying. Render passes are linear by default.
madmandrax_1
Thanks Beppe! Delecting the unused render setting sections did the trick. I'm surprised, that unchecked render options have that much effect. Now my picture viewer and live viewer output is almost identical.
