I've checked everything I could fine but I can't get my live viewer to match output in Picture Viewer.
Any ideas?
2019.1.5
Live Viewer vs Picture Viewer
Change the Render buffer type from Float (linear) to Float (tonemapped).BakerImageGroup wrote:I've checked everything I could fine but I can't get my live viewer to match output in Picture Viewer.
Any ideas?
2019.1.5
Float (linear) does not store any camera settings.
System:
i7 8700K / RTX 2020 / 16GB RAM
- madmandrax_1
Put your scene without any content, just current camera and keep render settings. Then I'll say what's wrongmadmandrax_1 wrote:I have the same problem. Render Buffer Type is set to Float (tonemapped), the liveviewer setting is set to HDR tonemapped. Any ideas?
- madmandrax_1
Thanks, find the project file attached.
- empty.zip
- empty project
- (210.75 KiB) Downloaded 171 times
Hi madmandrax_1,
you have not shared the HDRI, so the light cannot be the same, anyway, please avoid to mix OctaneRender settings with other render engines settings: And set the Geometry Engine to “All objects movable”: Looking forward for your feedback,
ciao Beppe
ciao Beppe
Deprecated options are meaning they will be removed sometime later.
Also, disable "use denoised beauty pass" for trying. Render passes are linear by default.
- madmandrax_1
Thanks Beppe! Delecting the unused render setting sections did the trick. I'm surprised, that unchecked render options have that much effect. Now my picture viewer and live viewer output is almost identical.
