OctaneRender™ 2020.2 RC2
arno
funk wrote:BUG: Composite node overwrites wrong pins when nodes are expanded
I just wanted to add a bit more info to the previous bug I posted here:
viewtopic.php?p=392217#p392217
This bug does not happen on saved scenes which already contain a composite node (I think). It only seems to happen after adding the node and doing these steps:
1. Add a composite texture. NOTE: If you hover over the node inputs, the far LEFT pin is layer 2 input, while right is layer 1
2. In the inspector, set layer 1 input to "checks"
3. Set layer 2 input to "noise"
4. In the inspector, right click the layer 1 input icon > expand
RESULT: The checks node expands but is attached to layer 2 input pin, which is wrong. It overwrites the previously connected noise node.
I added an image to make this clearer.
Thank you for reporting this. I haven't had a chance to look into its cause yet, but I can reproduce it.
pegot
I opened a file that was about a year old and I am seeing an issue where denoising is rendering a text label much thinker than it should be.
The file renders correctly with denoising on Octane 2020.1.5.
The problem appears with latest Octane 2020.2 RC2.
If Devs need ORBX send me info where to upload that (archived file is about 1.12 GB).
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
DamjanMX_1
Looks like that chaos texture is not baking into HDR even if it's set to.
DamjanMX_1
Is there a way I can make the scattered objects follow the displaced surface mesh?
lanklaf
DamjanMX_1 wrote:Is there a way I can make the scattered objects follow the displaced surface mesh?
Sure,
Connect the same Displacement texture to the Position Shader of Octane Scatter ;)
System:
i7 8700K / RTX 2020 / 16GB RAM
grimm
mojave wrote:
grimm wrote:This version doesn't find my GPUs on Linux. I'm running Nvidia driver version 455.28 which is higher than 455.23. Is there a problem with this version? Thanks,
Did you update your drivers recently and/or have the same issue with other recent or older versions?
Yes, I updated the drivers fairly recently. I just checked older versions and yep, they have the same issue. Must be a problem with this Nvidia driver version.
jobigoud
DamjanMX_1 wrote:Looks like that chaos texture is not baking into HDR even if it's set to.
This should be fixed in the next version.
Regarding scatter and displacement unfortunately the scatter happens on the non displaced mesh. In the case of a terrain you can plug the height map in the translation part of the scatter tool.
DamjanMX_1
jobigoud wrote: This should be fixed in the next version.
Great, looking forward to that fix!
jobigoud wrote: Regarding scatter and displacement unfortunately the scatter happens on the non displaced mesh. In the case of a terrain you can plug the height map in the translation part of the scatter tool.
Is there a plan in a foreseeable future to make it able to scatter on displaced meshes?
Thank you and @lanklaf for the tip.
grimm
The problem turned out to be that I didn't have the libglvnd-dev library installed. Once I installed it and re-built the driver, everything is working again. :) I'm now on driver version 455.45.01, thanks,
Jason
mojave
pegot wrote:I opened a file that was about a year old and I am seeing an issue where denoising is rendering a text label much thinker than it should be.
Would you be able to share a minimum repro case for this issue? You may share your file by the means that is most convenient for your and send a PM.
Thank you.
