Octane Geometry Properties
pepasystem
I would like to enable Subdivision for an object.
The modifier (Octane Geometry Properties) works on the whole scene.
How to make it work only on the selected object?
Octane 4.05 - 6.31
best
Dz
780TI, 980, i74770k, 32GB
paride4331
Hi pepasystem,
select you object, add "Octane Geometry properties" (modifier list) then encrease the subdivision level as you need.
pepasystem
Thanks for the answer.
Unfortunately, adding a modifier to one object affects all others in the scene.
paride4331
Hi pepasystem,
maybe you instanced the objects.
pepasystem
No,
OGP only on sphere.
pepasystem
Here is the scene.
octane.7z
(37.5 KiB) Downloaded 169 times
paride4331
thanks,
I can reproduce your issue.
I sent it to developers.
A work around is setting all objects "movable proxy".
pepasystem
Thanks.
Return to “Autodesk 3Ds Max”
