Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
aoktar wrote:
Ron wrote:Something is not working as expected with this release. Ron
wait a bit, it's not specific to this build. It's about re-forcing the bake operation for every parameter or something in osl script of noise.
Try this new build, osx on the way
viewtopic.php?f=85&t=74603&p=381681#p381681
Changes of 2020.1-R5 plugin
- Fix: Render buffer pitch issue on some case with even number on width when used upsampling
- Improvement: Better status info for processing the render passes in to Picture viewer, better and faster process/save for passes for some cases with lot of passes and when used individual files
- Fix: Long start times after a crash on big scene due to packing these to crash database
- Fix the limit for cycle parameter in c4d noises
- Fix: recreation and frequent updates of osl implementation of c4d noises to eliminate the performance bottleneck with baking node and others
- Minor revisions
Ron
- Minor revisions
GREAT!
This is running fast and seems to be stable. Will check that in more detail now.
Thank you for your quick help!
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
foureyez
Thank you for the fast updates! :)
protokol
Thanks for the latest R5 update Ahmet - much appreciated!
Cycles fixed which is great. Is getting the looping function a simple fix as well?
See attached project file for clarification. All the noises loop when OSL for C4D noise/gradient is turned OFF. When turned ON they no longer loop.
Cheers.
simplest noise test.rar
(140.75 KiB) Downloaded 160 times
rclassenphoto
Hi aoktar,
i add the octane Plugin in C4D R20 but the Programm does not load Correct it stocks at "Initializing Plugins....." and the Programm do not Open.... can you help?
I test it with octane 2019 and it works but nocht with octane 2020.
Today i test it in C4D R19 and it works without problems.
rclassenphoto wrote:Hi aoktar,
please, have a look at this post:
viewtopic.php?f=85&t=74603&start=120#p382526
ciao Beppe
rclassenphoto
hi Beppe,
i dont have this files in my corelibs folder. So this is not the problem.
cmittenaere
Thank you very mutch !
If i delete rtx option, I think is the best version of octane. Very very stable on a big scene now.
With rtx, more problem with big scene
rclassenphoto wrote:hi Beppe,
Delete any big files under _bugreports folder
ndreimi
I'm having crashes with an empty scene when i hit render.
Nvidia Studio driver 442.92
Current Octane Builds
Return to “Releases”
