A. Win 10.0.18362
B. 3 x RTX 2080 ti
C. 64 GB RAM
D. Nvidia Studio Driver 442.92
E. OctaneRender Enterprise 2020_1
F. OctaneRender plugin version 2020.1-R4
G. Cinema 4D R21.207
H. When I try opening this scene, it appears to be generating octane materials and then crashes. Note - I don't even have live viewer open when this happens. Unfortunately, I can't share a sample scene. When I hide certain objects from my viewport the issue goes away, but as soon as I make them visible again the crash returns.
Generating Materials Crash
C. RAM Capacity (i.e. 6 GB)
- jangeletti
- _BugReport.txt
- (400.58 KiB) Downloaded 221 times
- c4doctanelog.txt
- (5.16 KiB) Downloaded 177 times
before sending the scene to GPU, please go to c4doctane settings/Other panel, and press the Empty texCache button.
In 2020.1-R4 you can find the Empty TexCache command also in Live VIew menu Materials:
ciao Beppe
ciao Beppe
- jangeletti
Hello Beppe,
I have already tried this troubleshooting step both with this button under materials and by going to the file directory itself where 'tex cache' is located and it seems to have no effect on the issue I'm having.
Way 1 define is it specific to some objects or materials and prepare a sample scene for us. So we can test it.
Way2 put this log file to Cinema4d.exe location and run, replicate crash and send us "octane_log.txt" file
- octane_log_flags.txt
- behind to Cinema4d.exe location
- (229 Bytes) Downloaded 179 times
- jangeletti
Aoktar, thanks for your help. I pasted octane_log_flags.txt into C:/Program Files/Maxon Cinema 4D R21 (where Cinema 4D.exe is located). Then I replicated the crash again. See attached.
- c4doctanelog.txt
- (4.91 KiB) Downloaded 205 times
Sorry you posted wrong file, check what I wrote
- jangeletti
Sorry aoktar, I need more clear directions on how to do what you're asking for.aoktar wrote:Sorry you posted wrong file, check what I wrote
Ok
Put this log file to Cinema4d.exe location and run c4d,
replicate a crash
send us "octane_log.txt" file from root of c4d, not c4doctanelog.txt from prefs
replicate a crash
No, probably used texture import types? Right?mikeflex wrote:I'm experiencing the same crash. Had to remove octane from plugins folder just to get the scene to load. I will provide a bug report as well, should I create my own thread? there already seems to be a few. Thanks, Ahmet!
Using "Empty texCache" command can solve it temporarily
