Need Help for Textures.. Please..
JTCConstructors
I have an attached file here comparing the textures..
The first photo at the left side is rendered using artlantis..
second at the right side was octane..
If you could help me how to render the "transparency", i think, with octane similar with the first image at the left.
Thanks... :D :D :D :D
This photo compares about leaf texture of a palm...
JTCConstructors
I'm Talking about the leaf here.. please don't mind the other textures..
enricocerica
Hi, you need a opacity map (black and white) in addition to the diffuse map to get the transparency for the hidden part.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
JTCConstructors
Thank you for the reply to my concern..
If you don't mind, where should i put the opacity map with octane..?
enricocerica
On the material settings, you'll find the opacity tab, choose floatimage and select the corresponding map image, white part of the map will result in stransparency, you may also invert it if required.
JTCConstructors
hi mr. enrico,
Thank you for the tutorial, it works perfectly but, I have some problem with the shadow. Please see attached file..
Shadow problem...
Shadow problem...
shadow problem.png (210.64 KiB) Viewed 5590 times
enricocerica
Yeah, this is a known issue when using sunlight and opacity maps, this will be solved when the "MLT like" will be implemented, for now, you should live with it ;)
madcoo
Yep, for the moment Octane doesn't transfer the texture's transparency onto the shadows...
We'll have to wait...
2011 New Year Competition - 2nd Prize winning image
Visit my website: Fairview Studio 3D - Facebook page
i7 Quad-Core 2.67Ghz / 16Gb RAM / Windows 7 64bits / 2x GTX 680 / Octane v2.0 / CUDA Driver 6.0
JTCConstructors
Thanks for the help.. I really appreciated it... thanks...
suhail_spa
madcoo wrote:Yep, for the moment Octane doesn't transfer the texture's transparency onto the shadows...
well...i am waiting eagerly for this..
we do exterior architecture scenes- and mostly use opacity maps..
hope it gets implemented soon..(not to mention 'alpha channel' too.. :) )
(but found octane sooo impressive- i couldnt wait to purchase it.. rather than waiting for these small issues to get resolved)
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
Return to “Works In Progress”
