Hi kilad, look i have this problem, i set up my scene, export for still frame and everything runs just fine..., but when i render animations, it crashes both octane and 3ds max, i´m using 3ds max 2010 x64, last version of octane, and last version of max 2 octane... any ideas? this is the message i´ve got:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: C:\Users\criko\Documents\\TEST.ocs
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-aperture <float>] [--cam-focaldepth <float>]
[--cam-fov <float>] [--cam-motion-up-z <float>]
[--cam-motion-up-y <float>] [--cam-motion-up-x
<float>] [--cam-motion-target-z <float>]
[--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Camera Aperture Radius
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
--cam-motion-up-x <float>
Camera Up Motion 2nd Vector X Component
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
MAX2Octane exporter for max 2010+
I see a double \ for the TEST.ocs.
That should be the error...
face
face
http://vimeo.com/user2509578
Yes, Face is probably right. Make a new folder and press new project.
Hello
Hi
I need help
I have this message everytime I try to use the script:
If anyone could help please
Thank you
I need help
Couldn't read argument value from string '-267,179' Argument: (--cam-pos-x)
USAGE:
Where:
Camera Focal Depth
--cam-fov <float>
--cam-up-z <float>
--cam-up-y <float>
--cam-up-x <float>
--cam-pos-z <float>
--cam-pos-y <float>
--cam-pos-x <float>
-q, --quiet
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
--, --ignore_rest
--version
-h, --help
<filename>
Octane Render
Thank you
Rampage IV Extreme+i7 3920k+2x GTX580 3GB+2x GTX470
Hey yes it's the comma, should be a period. It's probably because of your language which is...I guess Spanish?
Anyway i find it strange that it is possible at all. I'll write a small fix!
Hello
hi, already checked the double // but still get errors, here i paste!
Couldn't find match for argument Argument: C:\Users\criko\Desktop\test\test.ocs
USAGE:
Where:
Camera Focal Depth
--cam-fov <float>
--cam-up-z <float>
--cam-up-y <float>
--cam-up-x <float>
--cam-pos-z <float>
--cam-pos-y <float>
--cam-pos-x <float>
-q, --quiet
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
--, --ignore_rest
--version
-h, --help
<filename>
Octane Render
HOPE YOU CAN HELP OUT WITH THIS!!!
USAGE:
Where:
Camera Focal Depth
--cam-fov <float>
--cam-up-z <float>
--cam-up-y <float>
--cam-up-x <float>
--cam-pos-z <float>
--cam-pos-y <float>
--cam-pos-x <float>
-q, --quiet
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
--, --ignore_rest
--version
-h, --help
<filename>
Octane Render
intel core i7-4960x 3.60 ghz
32 gb ram
win 7 64 bit
1x nvidia geforce gtx 780
1x nvidia geforce GTX TITAN
32 gb ram
win 7 64 bit
hi can anybody help me out with the render animation problem i posted upside?, thanksss! please!
32 gb ram
win 7 64 bit
32 gb ram
win 7 64 bit
Try it again and copy&paste the message in the listener here.
F11 to open the maxscript listener in 3dsmax. Copy the message after you get the error
k
k
Hello
UPDATE: Max2Octane 1.022g
@ttaberna: Download the latest script Max2Octane 1.022g. Hopefully 1.022g should fix your errors with commas.
http://www.refractivesoftware.com/forum ... hp?id=6758
good luck
k
good luck
k
Hello
