Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
divasoft
I found artifact in new release. A horizontal or vertical strip that shifts when i rotate camera.
The artifact does not appear in all cases. Some osl textures and noise in the scattering channel in OctaneFogVolume
bloomis2
Hi, thanks for the great release!
Just a thing: when I click on Compare > Store render buffer, the image stored is out of proportions and I can't move the line bewteen A and B anymore.
I had no issues with the RC3 regarding this.
After clicking
After clicking
Before clicking
Before clicking
bloomis2
mitchino wrote:Do c4d noises work with displacement? I can't seem to get that to work, tried plugging a c4d noise into displacement, no result, tried plugging c4d noise into bake texture then displacement, Octane froze.
I did a quick test and it works for me.
Is it the proper way, though?
bloomis2 wrote:Hi, thanks for the great release!
Are you using desktop scaling?
Works just with vertex displacement
Clarawhite
Hi, I can't seem to turn on the RTX acceleration. I have 3x RTX 2080 and updated to the latest studio drivers, but it's just grayed out every time I try to use it.
KeeWe
When using Right Click - Pins - Show all in the node editor, the Typo of the pins get blurry. See the attached screenshot
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
martinzip
Dear Ahmet thank you very much for the new update! On my system macos10.13.6 the c4d plugin works in R19 and R21 but not in R20 ...
It does not appear in the menu and is like it were not installed ...
Never had this behaviour before. Thanks in advance for your help
kind regards from cologne
Martin
martinzip wrote:Dear Ahmet thank you very much for the new update! On my system macos10.13.6 the c4d plugin works in R19 and R21 but not in R20 ...
Martin
What's numbers of R20 and did you deleted other plugin dlls?
martinzip
Build R20.059
other dll are deleted....
Return to “Releases”
