I found artifact in new release. A horizontal or vertical strip that shifts when i rotate camera.
The artifact does not appear in all cases. Some osl textures and noise in the scattering channel in OctaneFogVolume
Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
Hi,mitchino wrote:Do c4d noises work with displacement? I can't seem to get that to work, tried plugging a c4d noise into displacement, no result, tried plugging c4d noise into bake texture then displacement, Octane froze.
I did a quick test and it works for me.
Is it the proper way, though?
Are you using desktop scaling?bloomis2 wrote:Hi, thanks for the great release!
Just a thing: when I click on Compare > Store render buffer, the image stored is out of proportions and I can't move the line bewteen A and B anymore.
I had no issues with the RC3 regarding this.
Works just with vertex displacementmitchino wrote:Do c4d noises work with displacement? I can't seem to get that to work, tried plugging a c4d noise into displacement, no result, tried plugging c4d noise into bake texture then displacement, Octane froze.
- Clarawhite
Dear Ahmet thank you very much for the new update! On my system macos10.13.6 the c4d plugin works in R19 and R21 but not in R20 ...
It does not appear in the menu and is like it were not installed ...
Never had this behaviour before. Thanks in advance for your help
kind regards from cologne
Martin
Martin
What's numbers of R20 and did you deleted other plugin dlls?martinzip wrote:Dear Ahmet thank you very much for the new update! On my system macos10.13.6 the c4d plugin works in R19 and R21 but not in R20 ...
Martin
