Indoor Area Lights / Emitters tips
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
rman1974
Nothing new - just usual way to keep your images less noisy. It works for any unbiased render
1. Keep emitter away from geometry (if it's possible)
2. It's better to use single side geometry for emitter (normal is pointed to scene)
3. It's better to use diffuse material for reflector
matej
Nice research, thanks!
cgmo.net
radiance
maybe this can go into the resources forum ?
Radiance
Carl S.
With a little more info on the specific setups other than just icons. Thanks
[gk]
Carl, its pritty simple.
The blue half circle is a lamp shader. So whenever that is present on the icons it measn there is a shader in play.
The yellow icons should speak for them self, they have clear shapes and arrows.
-mads
Amiga 1000 with 2mb memory card
rman1974
radiance wrote:maybe this can go into the resources forum ?
Radiance
I thought about it when I was writing a post :) Yes, maybe it would be better to move it in the resource forum
rman1974
Carl S. wrote:With a little more info on the specific setups other than just icons. Thanks
Hm, I don't know what else I can tell about lights setup. Arrows show normals. Reflector is two sided geometry. That's all :)
radiance
I'll rename this thread to 'Indoor Area Lights / Emitters tips' and make it sticky in the resources forum.
Thnx,
Radiance
Diogo Moita
Very nice info! Thanks!
i7 930, 12Gb, 2x GTX470
http://www.3dm.com.br
Tugpsx
Thanks for your research, This will help with simulating IES light effects in Octane.
Again thanks for sharing and the quick explanation of the icons.
Return to “Resources and Sharing”
