Two of the textures are set to float, three are set to "Type: Normal", but the VRAM usage is the same:
Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
Hi - I've found a bug: setting a texture to float is ignored.
C4D 2025 | Win10
Hello,
FYI:
When using RENDER INSTANCES where the original (source) object is hidden under a null *and* the "ignore unused materials" render setting is enabled - the instances will get a random scene material assigned, instead of the materials assigned to the original (source) objects.
B.
FYI:
B.
Hello, Aoktar:
I found a crash that happens everytime I toggle multiple images "Type". The backup .c4d file generated becomes useless as it crashes again as soon as C4D reopens it.
- oct DAT.TXT
- I renamed the oct.dat to .txt as I am not allowed to upload .dat files.
- (2.03 KiB) Downloaded 308 times
- c4doctanelog.txt
- (3.45 KiB) Downloaded 312 times
C4D 2025.1.1 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
So, is this going to be adressed? It is quite an important feature for saving Vram.
zoppo wrote:Hi - I've found a bug: setting a texture to float is ignored.
C4D 2025 | Win10
