Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
Hi all,
This is new build with a stable version of 2019.1.5 SDK.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1.5.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2019.1.5-R3 C4D plugin
  • fix: missing deepExr saving for frames before last one
  • fix: embedded gui grab on unvisible parameters while drag
  • fix a crash on oslCamera if octane is not activated
  • wrong parameter assignment on universalCamera, for "pixel aspect ratio"
  • support relative filenames in 'orbx loader' object
Changes of 2019.1.5-R2 C4D plugin
  • Picking volume objects from LV
  • Osl filename parameter, save as assets support
  • Vectron support in Node Editor
  • Multi storage for image comparison
Changes of 2019.1.5 C4D plugin
  • Avoiding same material names on creations
  • Fix delay on loading of texture manager with a lot of textures
  • NodeEditor icon added in to some octane objects/tags for quick access
  • Scatter object should detect the animation updates on clone better than before
  • Performance improvement: Multi-threading support for material creation on sending a render. Activate it by Settings->Other->Multi-thread for materials
  • Missing first clone of multi-instances
  • Avoid lags due to unnecessary updates for VDB object under cloners
  • Performance fix for vdb object for viewport
  • Detection the animation for C4D noises
  • Fix: Custom lut strength
Changes of 2019.1.5 SDK
  • Improved rounded edges rendering (in accurate mode). The rounded edges node has now a new pin Samples which allows you to control the accuracy of the rounded edges. The higher its value the better it handles corner cases like sharp corners and edges but also takes longer to calculate.
  • Fixed autobump which didn't work correctly for projection types other than mesh UV (see viewtopic.php?p=372548#p372548).
  • Fixed missing updates in displacement mixer trees (see viewtopic.php?p=372294#p372294).
  • Fixed incorrect access of pins during set up of displacement causing error message "Tried to access null node" (see viewtopic.php?p=372317#p372317).
  • Fixed microfacet BRDFs for metallic/universal materials with high roughness (regression from 2018.1).
  • Fixed the default behavior of universal material when the roughness pin is not connected.
  • Fixed dirt node not working with composite materials (see viewtopic.php?p=372738#p372738).
  • Fixed too bright rendering of glossy surfaces behind specular surfaces with the direct lighting kernel in diffuse GI mode.
  • Fixed fake shadow being switched off when albedo is > 0 in universal material (see viewtopic.php?p=374532#p374532).
  • Fixed mix material being ignored when it is connected to a layered material (see viewtopic.php?p=374501#p374501).
  • Fixed slightly incorrect sampling of importance sampled environments.
  • Fixed various memory leaks in Octane and libraries used by it.
  • Fixed access violation when changing render geometry and peer-to-peer memory (NVlink) is being used.
  • Fixed crash when expaning an universal camera out of a node pin.
  • Fixed broken connection after an externally connected camera node gets replaced by an universal camera graph.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
The attachment R15-res.rar is no longer available
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(431.84) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
Multi-threading for material creation
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Kalua
Thank you, Aoktar!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua wrote:Thank you, Aoktar!
You're welcome, enjoy it!
shine71
Thanks Ahmet!
I quickly tested on previous scenes and it looks glasses look darker and let less light pass through.. could you help me to know why?
Thanks a lot for your work, man!
poison
shine71 wrote:Thanks Ahmet!
Same with me Ahmet. wanted to try on my current project that features animated c4d noises (work in this release YES!!!) but i have lots of glass and transparency in general so that's a BIG NO NO. all comes pitch black.
materials are much much faster, absolutely lovely.
How soon can we expect that 2019.1.5-R2 ?
love.
Win10, 4 x 1080Ti
Win10, 2 x 2080Ti, 2 x 980Ti
I cannot know, rendering is a core function. Put a sample to show it!
love.
Are you using the direct lighting kernel diffuse gi with fake shadow on the glass enabled? Also thanks!
poison
love.
Ahmet , belive it or not, my problem was solved with a simple PC restart.
Tested in R19, R20 and R21.
Win10, 4 x 1080Ti
shine71
love.
Hi again Ahmet!
Yes, exactly.
We're using DL diffuse GI with fake shadow enabled.
Any tip?
Thanks a lot!
PS: new material conversion works like a charm!!!
DMAEuropa
Will 2019 ever get RTX? i know we have 2020 XB but i see 2019 is still getting updates
